RV.Net Open Roads Forum: Fifth-Wheels: Chucking
 > Chucking
Mile High
Denver, CO
Posted: 05/09/12 09:43am Link  |  Print  |  Notify Moderator
BB_TX wrote:
As noted, sometimes it is just a matter of loading. Playing with that may solve your problem.
But a new pin box can help also. I had very little chucking on mine, and that was mostly just on certain concrete highways. I replaced the stock pin box with a 5th Airborne air cushioned pin box and it eliminated virtually all the chucking that I did have. Plus eliminates some of the shock from the trailer and makes the truck ride better.
X2 on the 5th Airborne. I think any of the pin boxes designed to minimize chucking do what they say.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
laknox
Arizona
Posted: 05/09/12 10:10am Link  |  Print  |  Notify Moderator
CMC wrote:
The fresh water tank is forward of the axles. I'll try towing with it full next. Thanks.
I'd play with it a bit. You don't want to haul an extra 200-300 lbs, when 100 will do the trick. :-)
Lyle
1936 John Deere Model A
Biggziff
Upstate, NY
Posted: 05/09/12 10:15am Link  |  Print  |  Notify Moderator
The only time I've had chucking with any of our 4 fivers with 3 different trucks (F150 5.5' bed, F250 8' bed and current F350 6.5' bed) was when we were on a road surface that was uneven or not flat from heavy traffic. On smooth roads I get none at all.
I'm using an old RBW Lil' Rocker hitch.
* This post was edited 05/09/12 10:53am by Biggziff *
Me and my 3 girls
2013 Cougar 293SAB
2011 F350 CC SWB 6.7
Ford Man
Tennessee
Posted: 05/09/12 10:39am Link  |  Print  |  Notify Moderator
When i traded the SRW Short Bed with a Slider Hitch for a DRW Long Bed and a B&W Hitch with the Companion, there was no more Chucking. Had to be in the Slider part of the Hitch.
texas_train
Great State Of Texas!
Posted: 05/09/12 11:54am Link  |  Print  |  Notify Moderator
K.I.S.S. keep it simple stupid!
First check things that are cheap/easy. Procede in logical order.
check hitch is it worn? need adjustment? lubed properly? locking tightly? Check weight dist in trailer, like another said add some water to tank if in front of wheels (NOT the same as adding wieght to truck bed)Check on level smooth roads, and uneven rough one's
check to see/get truck and trailer as level as you can with the adjustments on hitch and trailer. If you do all that and still feel that youl'd like to be smoother... I'd first try least expensive option, adding airbags to truck suspension this will recover truck height and will smooth the ride conciderably. firestone and Air Ride make kits that are easy to assemble/install and about 1/2 $$ of pin airbag systems. Still not good enough?!?! Then go to a "pin cushen" system like mor ride or Trail Air (second most expensive hitch cushening ) Or the actual air bag cushen hitch (most expensive but I don't think they come in a slider auto or not)
Our newest came with the Trail Air pin box. I installed Firestone Air bags on TV, and have 16K pull rite superglide auto slider hitch.
Que Suave!(smoooooth!) Like a baby's butt!!
2012 Cedar Creek 36 RE Touring ED, all avail options
2011 GMC 2500 HD Denali DMax 4wd Superglide firestone bags
95' Procraft V-180-C 120HP OB, 80# cust TM, side/down image sonar
Don and Rosie, Annie the wonder Dog
clicky to our photobook album
routemaster
Deming
Posted: 05/09/12 01:37pm Link  |  Print  |  Notify Moderator
Put Monroe shocks on her.
2005 GMC 2500Dmax C/C S/B with 06 air box.
Reese 16k Slider hitch.
2006 Everest 344J.3500lbs springs, Monroe shocks, LED taillights Travelsoft water softener.
YAMAHA EF3000iSEB
Fulltimers
Verizon Air Card.
remoandiris
Posted: 05/09/12 02:14pm Link  |  Print  |  Notify Moderator
CMC wrote:
The first time I towed our 5th wheel I noticed it seemed like the truck was surging forward and back. Is this what they mean by chucking? What causes it and is there anything I can do to prevent it. Either by driving habits or installing something. Thanks
I solved it by purchasing a used 25K air ride hitch. I will move it from my current truck to my next truck whenever that happens. Yes, it is expensive up front, but the ride is fantastic. Put over 10K on it so far this year. Best part...it solved my problem instantly. No searching for the perfect amount of water in the tank, perfect gain setting, perfect airbag pressure, etc. And like I said, I will move it to my next truck. You going to do that with airbags?
2011 GMC 3500 Dually
New to me 2006 Jayco Designer 38RDQS
2 Boxers and a Maine Coon
CMC
Columbus, TX
Posted: 05/09/12 02:47pm Link  |  Print  |  Notify Moderator
Thanks for all the great advice. To answer some questions. The camper does sit level. The truck only squats about 2" when hooked up. It is a brand new trailer and hitch. It is a Husky 16K sliding hitch. Again thanks for the great info.
2012 Ford F-250 Lariat
4x2 6.2 liter Crew Cab
Keystone Copper Canyon 273FWRET
US Navy Retired
okiejoe
Oklahoma City
Posted: 05/09/12 02:53pm Link  |  Print  |  Notify Moderator
Moryde pinbox, agree I have had 2 5ers and had chucking problems on both and solved the problems on both 5ers. Now remember, you are towing a trailer and the ride will be differant from a car. but MorRyde Pinbox is the best, also Tweetys is the best price and fast shipping, They are located in Texas and you may be able to just go pick it up.
gmcsmoke
Butler
Posted: 05/09/12 05:22pm Link  |  Print  |  Notify Moderator
You don't need moryde for a 10K GVW camper. I also question how level it really is. A 2012 F-250 and a trailer with 15" tires makes me think it's out of level by a few inches and that's what is causing the chucking.
 > Chucking
