jonnyk
minnsota
Anyone use a Tahoe/Yukon to pull a trailer.I looked at a 2500 Suburb 454 ci but way too thirsty as a daily driver so might go a bit smaller. I 'm downgrading from a class a so my options are somewhat open as far as trailer length and weight. Any issues with a midsize suv? We don't camp a whole lot so it won't be heavily used. Any trans or drive train problems? Engine issues? 5.3 or 5.7?
Thanks for the replies
Dick_B
Palos Heights, IL USA
If you don't camp a lot have you considered renting?
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
Kemahsabe
Kemah, TX
Here's a recent thread on the subject.
JKQ
I've owned three Yukons over the last dozen years & loved each one. I never had a problem with any of them. Regarding miles per gallon, I feel that if you're going to tow a 30ft or larger trailer you need the larger engine & a 373 rear end. Milage will suffer but thats part of owning a truck with a big power plant. I too downsized from a Class A & my advise would be to shop carefully for the TT before you purchasr a tow vehicle, as you may end up with a pretty big trailer.
2013 CruiserRv Enterra 314 RES TT, 36ft, 3 slides
2011 GMC 2500 Denali, Diesel/Allison, 4 wheel drive crew cab
Reese WD hitch with dual friction control bars
Dometic 3000 KW portable genset
donn0128
Pronounced Ore-gun
GM ended 5.7 production a lot of years age. The only motor available in recent Tahoe is the 5.3. It is still thirsty. Step up to a Suburban, get the 6.0 and go camping. It is still thirsty, but at least you will be able to tow a trailer larger than 25 feet
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
na2b
I have a 2011 Tahoe with hd towing & built in brake controller - I tow a 28 ft trailer with no issues - I get 22 mpg daily & 11 mpg towing.
adrianb
Longview, WA
Hey Jonny -
I have a 2003 Tahoe with the 5.3 motor. I tow a 24' KZ Sportsman which I *think* is around 4,000 pounds dry. I have a brake controller and weight distribution/anti-sway hitch and have had zero problems. I haven't towed much so I don't have a lot to compare to, but I bought the trailer to fit my Tahoe. I am getting close on weight limits but am within spec.
I have had no issues with the transmission or engine, it's all been great. I too have considered selling the Tahoe to buy a more fuel efficient daily driver and renting a larger truck/SUV for towing purposes but the dollars don't work out. The cost to rent plus the hassle isn't even close to being a savings for me. YMMV.
Sbeach99
Concord, NC
na2b wrote: I have a 2011 Tahoe with hd towing & built in brake controller - I tow a 28 ft trailer with no issues - I get 22 mpg daily & 11 mpg towing.
I would LOVE to know how you get 22mpg. I'm getting 17.2 or so tops on my 2011 LTZ 4x4. Are you 2WD or 4WD?
Scott
Just your average family trying to unplug every now and then!
2012 Coachmen Catalina 21BH
2011 Chevy Tahoe 4x4 LTZ
EAZ-Lift WDH
Sbeach99
Concord, NC
I tow my 4200 lb Coachmen + dogs, gear, etc behind my 2011 4WD LTZ with no issues at all. I traded out of a 2005 4Runner V6 for the Tahoe in order to have more margin of safety. I was well within my tow rating for both (using a WD hitch) but with the Tahoe I always feel that even uphill, in the rain, at night, etc I would still have enough extra mmmmphh to react to an unexpected issue.
na2b
Sbeach99 wrote: na2b wrote: I have a 2011 Tahoe with hd towing & built in brake controller - I tow a 28 ft trailer with no issues - I get 22 mpg daily & 11 mpg towing.
I have a 2WD - most of my daily is back & forth to work on interstate @ 65 mph. I check frequently with trip & on board computer. Tow @ 55-60 mph again usually interstate also tranny temp has never exceeded 190. Pretty happy with the Tahoe
