RV.Net Open Roads Forum: Towing: Upgrading to E-rated tires
Search only in Towing
Open Roads Forum  >  Towing
 > Upgrading to E-rated tires
mowermech
Billings, MT
Posted: 05/26/12 08:52am Link  |  Print  |  Notify Moderator
lbrjet wrote:
Not surprising Michelin recommends a minimum 50 PSI. I have never seen a tire maker recommend anything less. Some people run less than 50 in their 'E' rated tires to achieve a smoother ride, but that is not recommended because of excess heat buildup due to underinflating.
And yet, Jeep put E rated tires on my '06 Rubicon at the factory(for side-wall strength, not load capacity), at an inflation pressure of 33 PSI.
I made several long distance trips on those tires, at freeway speeds of 70 to 75 MPH, with no tire problems at all!
When off-roading at low speeds, I would air them down to 12 to 15 PSI, and run all day over the rocks. No trouble there, either. As soon as we got back to a "real road", the tires were aired back to the recommended 33 PSI.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
Exrhodie
Chilliwack B.C.
Posted: 05/26/12 09:19am Link  |  Print  |  Notify Moderator
I replaced my tires in January to Khumo RoadVenture SAT KL61 113s 265/70r/17
Max Load 2535lbs
Max Psi 51
They run great, very smooth,When towing pump them to 51 psi. When I am not Towing they are at 40psi
You don't need LT tires on your truck for that trailer.
Theunis,Karen and 2 adult daughters
07 CC Silverado Classic 1500 Z71 5.3l 4.10axle
HD tow package
Reese WDH
09 Jayco 23B HTT
BenK
SF BayArea
Posted: 05/26/12 10:28am Link  |  Print  |  Notify Moderator
Again, it depends on that tires loading, but yes there is a min for each speed
range (squirm and the flexing generated heat)
Just taking a PSI by itself is out of context
Why my chart is really a bit off, as I took those curves to ZERO, which
is incorrect.
A ZERO PSI mounted tire has some level of carry capacity...not ZERO,
but it will flex too much and generate too much heat...the biggest
enemy of any tire
