RV.Net Open Roads Forum: Towing: Upgrading to E-rated tires
Search only in Towing
Open Roads Forum  >  Towing
 > Upgrading to E-rated tires
jerem0621
Sequatchie, TN
Posted: 05/09/12 08:58am Link  |  Quote  |  Print  |  Notify Moderator
Another option is P-XL tires. They give a good ride and increased load capacity.
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
fla-gypsy
North Florida
Posted: 05/09/12 11:28am Link  |  Quote  |  Print  |  Notify Moderator
I would switch to the LT's in a comparable or slightly higher load range
BenK
SF BayArea
Posted: 05/09/12 11:45am Link  |  Quote  |  Print  |  Notify Moderator
jeshoffstall wrote:
Sorry guys, did not mean to confuse the issue - I meant going from a P rated tire to an LT tire. Looking at Michelin's site, I see they now make an LT tire in the same size as my current P rated tire.
Specs are:
P rated, P275/65R18, max load 2365@44 psi
LT rated, LT275/65R18/E, max load 3415@80 psi
My TT has a dry weight of 4,991, GVWR of 6,550 and a dry tounge weight of 597 (have not yet got the rig on the scales).
Possibly the LTs are overkill?
Thanks,
Jack
So much out of context
Maybe this break down on the different classes and metrics might help
There are different 'classes' of tires. Below list is from the lowest
to the highest
  • ST, are trailer tires and has a 65mph limit
  • P, are passenger CAR tires
  • LT, are light truck tires
  • Commercial, are for the semi's
  • off road, are those you see on hugmongo dump trucks...those tires are in the 8 feet/dia range
Then their load ratings.
  • 'P' class tires use a numeric designation that has a specific weight rating in pounds
  • 'LT' class has a ply rating and goes back to the days when they actually has that many number of plys (today's only has 2-3, generally) and are going to the numeric ratings (too confusing to so many)
  • 'Commercial' and 'ST' also use
    ply ratings
Then folks taking the letter ply rating as if it is an end all are
taking it out of context.
An 'E' by itself has no meaning without the size, other than it is a 10 ply rating
Then it's not just the weight rating, but the class that makes the
biggest difference.
Also note that a 'P' class tire used on a pickup/SUV must be de-rated
a min of 9%. The OEM's have already done that with the 'P' class tire
they supplied with most all half ton trucks/SUVs (except for the fake
half tons with a +8K GVWR)
-Ben Picture of my rig
mkirsch
Rochester, NY
Posted: 05/10/12 11:30am Link  |  Quote  |  Print  |  Notify Moderator
You're going to end up running the LT-E rated tires underinflated, and at well below their rated capacity, on the stock rims.
I used to run LT-rated tires on my 1/2 ton in the winter.
The 225-75R16 LT-E rated snows are rated at ~2800lbs each at 80PSI.
The 235-75R16 P rated OEM tires are rated at 2094lbs each at 44PSI.
800lbs difference, yes, at a pressure I could not achieve with the stock rims. At 40PSI both tires ended up with roughly the same weight carrying capacity (around 2000lbs each).
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
jeshoffstall
Snellville, GA
Posted: 05/10/12 11:49am Link  |  Quote  |  Print  |  Notify Moderator
Thank you - that is the most clarity I have seen on the issue. I also email Michelin directly to get their advice, but will probably just stick with P rated tires since I not over capacity now.
2010 Tundra DC 4x4 5.7 w/Tow Package, LineX, Tonneau
2012 Flagstaff V-Lite 21WRS
Equal-i-zer WDH 1K
Mary Beth (DW)
Kirby & Khloe (camping pugs)
kpratte
Southern NH
Posted: 05/10/12 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
I'm getting LT tires tomorrow.. You can email the manufacturer to find out what PSI you need to get 2600lbs (max load of the stock tires) of load capacity out of the tires. Using Goodyear's load tables it's 55psi for 2660lbs for a LT275/65-18, but YMMV.
For reference the Tundra Rock Warrior comes with LT tires (17 inch) and they run them at 46psi when not towing.
Don't make the mistake of thinking that the LT tires will only need 30psi like the door placard says.
- Ken
2010 Toyota Tundra 5.7 CrewMax Limited, TRD Swaybar, Timbrens, Bilstein HD shocks
2012 Keystone Sprinter 272BHS
Reese DC Sway, Fastway Flip, Tekonsha P3
Yamaha 2400iSHC Generator
jeshoffstall
Snellville, GA
Posted: 05/25/12 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Email response from Michelin:
My Tundra currently has P 275/65 R 18 tires and the door jamb sticker shows 31
PSI front and 33 PSI rear.
Want I want to do is upgrade to the M/S 2 LT 275/65 R 18 (same size tire,
but in higher weight rating) to increase stability while pulling a trailer.
I was interested in what PSI I should use for the LT tires vs. the current P
rated tires on my vehicle? I see folks on internet forms running 50-60 PSI
in these tires, but would like Michelin's recommendation.
The minimum recommended PSI for the LT275/65R18 tires would be 50 front and 55 rear. Remember to check the PSI when the tires are cold.
We appreciate your business and thank you for choosing Michelin.
goducks10
Keizer OR
Posted: 05/25/12 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
Very interesting, thanks for doing that. Should clear up some of the confusion.
BenK
SF BayArea
Posted: 05/25/12 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
jeshoffstall wrote:
snip...
The carry capacity vs PSI is pretty linear and you can do the simple math yourself
Best to have actually weighed your axle loading
For folks who want a PSI number and went to the OEM...note their verbiage
'Minimum recommended' is out of context if your axle load is not what they
used to develop that recommendation...
Made up this chart decades ago for a magazine article on LT vs P
class tires and how can two different sized tires have the same
max load ???
Note how linear the 'curve' is...that blip is from their typo info
provided to me for that article
lbrjet
Liberty, IN
Posted: 05/26/12 08:05am Link  |  Quote  |  Print  |  Notify Moderator
Not surprising Michelin recommends a minimum 50 PSI. I have never seen a tire maker recommend anything less. Some people run less than 50 in their 'E' rated tires to achieve a smoother ride, but that is not recommended because of excess heat buildup due to underinflating.
2010 F250 4X4 5.4L 3.73 LS
2011 Flagstaff 831FKBSS
Equalizer E4 1200/12000
