cummins5.9
Prince George, BC Canada
Like the title states my floor split over winter. My trailer is a 09 Jayflight G2 25RKS and it split in 4 place around every floor vent. I wa wondering if this is common and if Jayco has been fixing this problem. Thanks.
FuzzyBob
SE Michigan
Could you give more information on what you mean by "split"? Is it the vinyl floor, the wood under it, or both?
2008 Suburban LT/Z71 4X4
2012 Rockwood 2304 Trailer
1 Big Fuzzy Geek (me)
1 Awesome Cookie Baker (DW)
2 Goofy Dogs
Nights camped in 2011 - 17 (not enough!)
cummins5.9
The vinyl floor split open in four places. Also know as a cold crack.
stubblejumper
Saskatchewan
Type
finally the cold got me
in the seach box and this will take you to previous discussion with about 30 replies on this subject
Wayne
1999 Winnebego Chieftain
Wayne & Leila and Teddi (the Kid in the brown fuzzy pyjamas)
We are not 2 people that own a dog, we are 2 people that are owned by a dog ..
fla-gypsy
North Florida
This is a phenomena that we hear more about each year. I never heard of such a thing 5 years ago. I suspect it has something to do with the materials the floors are being constructed of now versus the past.
Big Love
SF Bay Area, CA
It has to do with the way the flooring is installed in RVs and follows a drop in temperature. The floor was installed before the cabinets, so the edges are fixed in place. When it gets cold inside the trailer, the flooring contracts and since fixed in place on the edges, once it contracts enough, it rips.
DutchmenSport
Between Anderson, Pendleton, & Lapel, Indiana
Our shower surround cracked the 2nd year we owned our current TT. It was an extremely cold winter (like 20 below for days). The surround is installed with screws on the edges. No room for expansion or contraction of material (some kind of PVC plastic stuff like most are made of). Well, we never replaced it. It still has the crack, but I've used silicon putty and just covered up the crack. The silicon allows for the expansion and contraction now. And the crack has never gotten bigger. I figure, if I ever sell the camper ... which will probably be never ... I'll go to Home Depot or Lowes and find a replacement, like you'd put in your shower at home (a wall panel type). Until then, it's perfectly fine the way it is.
Fixing your floor might be a bit of a challenge. You might just look into covering the entire floor with carpet now and be done with it. Swapping out the vinyl will be a bit of a challenge, especially with it being originally installed on the floor first and then cabinets and wall put on top of it. It's easier to just cover it and move on.
After remodeling 2 houses, completely ... EVERY room, restarting from the studs outward, installing a bit of carpet in a camper is nothing.
DutchmenSport
2005 Chevy Silverado 3500 Dually Duramax 6.6L V8 Turbo
Century Truck Cap Commercial /Toolboxes
Northeast Outfitters Canoe
2006 Keystone Springdale Model 263DBL
Weight 4985, Carrying Capacity 2575, Hitch 560, Length 30'
Width 8', Height 10' 6"
SWD
Land of Living Skies
DutchmenSport wrote: Our shower surround cracked the 2nd year we owned our current TT. It was an extremely cold winter (like 20 below for days). The surround is installed with screws on the edges. No room for expansion or contraction of material (some kind of PVC plastic stuff like most are made of). Well, we never replaced it. It still has the crack, but I've used silicon putty and just covered up the crack. The silicon allows for the expansion and contraction now. And the crack has never gotten bigger. I figure, if I ever sell the camper ... which will probably be never ... I'll go to Home Depot or Lowes and find a replacement, like you'd put in your shower at home (a wall panel type). Until then, it's perfectly fine the way it is.
I concur. Having said that, nothing beats laminate for durability, which is what I did about 7 years ago. It still looks like new. Also glued a heavier lino on top of existing one. Still there today with no issues.
cummins5.9
Jayco offered $500 towards the fix, if it was in another month they would have done nothing.They are calling it a good will repair, something tells me it is very common occurance.
CAMP_MLMM
Sault Ste. Marie, ON, Canada
This happened to me with our previous Trailer (Rockwood Roo Hybrid) What we did to replace it was we found for lack of a better name, peel and stick tiles. They are vinyl tiles and have a strong adhesive back. I cut the cracked linoleum back to the walls and edges of cabinets and installed the tiles with ease and it looked as good or better than factory linoleum did.
2011 Passport 2910BH
2011 Chevrolet Silverado 5.3L Crew Cab
