I forgot to take the breakaway switch of off the Jeep we traded in. There are quite a few manufacturers of breakaway switches; IE OEM, Tekonsha, Curt Manufacturing, Hopkins, Fastway.
Are there any manufacturers I should stay away from? Does one manufacturere stand out over the others?
I don't mind spending a few more dollars for one that can handle the road salt in the norheast. I only want to do this once.
Because there are no electronics involved, (just a simple make break switch) I don't believe it makes a whole lot of difference. When the I needed one, I went go Ebay and got it delivered for $10.
Ooops Brain fade. I didn't see this was for a toad. That may be a way different breakaway switch than a trailer uses.
edited 05/09/12 03:09pm by powderman426 *
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
powderman426 wrote: Because there are no electronics involved, (just a simple make break switch) I don't believe it makes a whole lot of difference. When the I needed one, I went go Ebay and got it delivered for $10.
I believe it is the same. I have seen corroded ones on cars where they do not look they have held up well to the environment.
Tekonsha makes 3 models with a couple of versions of each.
The Tekonsha 2005-B120 will work fine. I added one to my 2nd toad rather than move a switch back and forth between toads. Any trailer store should be able to supply a switch also. Simply add a length of wire with banana plugs and you're good to go with your Brake Buddy.
2005 Bounder 37U Cat C7 Engine
2014 Jeep Grand Cherokee Limited
2002 Dodge Durango SLT Plus 4X4
ARRL Extra Class Volunteer Examiner
FAA A&P License
1969 Plymouth Road Runner
Thank you. We also have two Jeeps we tow. I have been waiting for the baseplate to arrive before I ordered the breakaway. Since Tekonsha makes two different types, I was waiting to pull the bumper cover to see which type would fit best.
The only one I can find locally is a Hopkins, so I will order the Tekonsha 2005-B120 over the internet.
Thanks again,
Paul
edited 05/12/12 07:34am by ploiselle *
