RV.Net Open Roads Forum: Towing: Can I just replace with OEM towing mirrors?
Search only in Towing
Open Roads Forum  >  Towing
 > Can I just replace with OEM towing mirrors?
AJP69
Manhattan, KS
Posted: 05/09/12 06:26pm Link  |  Print  |  Notify Moderator
Ok I have a 2005 Ford F-250 Super Duty that does not have factory tow mirrors installed. The mirrors that are on my truck have power adjustment but no turn signal nor heat. I would like to replace with OEM style F-250 mirrors, but retain the power control. I have been looking at these Click Me. They say they have power control and are direct OEM replacements. Just want to make sure before I spend $150 these will work for me.
2012 Jayco Jay Flight Swift 264BH
2005 Ford F-250 6.0l diesel
Home Skillet
Pearland Texas
Posted: 05/09/12 07:58pm Link  |  Print  |  Notify Moderator
I can't say for sure.
I do know that the factory tow mirror accessory kit comes with the necessary wiring harness adapters to make them work.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,SmarTire,Bilstein Shocks,Trans temp guage,Lowrace iWAY
beermanjoe
Pa
Posted: 05/10/12 03:45pm Link  |  Print  |  Notify Moderator
I put OEM towing mirrors on my 07 1500 Ram.Power and heat both work fine.
ecoast
NW NJ's Highlands
Posted: 05/10/12 12:22pm Link  |  Print  |  Notify Moderator
yes; if yours are only power, and the one linked is only power, you should be good to go...
send the seller a message and ask as well; that way if 'no fit' you can return on their dime...
07 5.9 CTD & 2000 Northstar Laredo TC towing 87 Samurai ORV on dual axle trailer
bpounds
Whittier CA
Posted: 05/10/12 04:18pm Link  |  Print  |  Notify Moderator
If the product picture is correct, I would not buy those. They are the older style that only swings one way. The newer style swing both ways, which prevents breaking them if something happens.
Also, you can get a kit to retro-fit the newer '08 mirrors to your '05, and they have much larger glass and a better convex lower glass. They bolt right up and plug in.
I can show you some links if interested.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
AJP69
Manhattan, KS
Posted: 05/10/12 04:38pm Link  |  Print  |  Notify Moderator
Sure id like links.
bpounds
Whittier CA
Posted: 05/10/12 04:41pm Link  |  Print  |  Notify Moderator
These guys have a good selection:
Side Mirrors at 1AAuto.com
They even have a video showing how to swap them out.
AJP69
Manhattan, KS
Posted: 05/10/12 05:27pm Link  |  Print  |  Notify Moderator
Yeah at twice the price. From what I read if the stock mirror didn't have turn signals and heat they wont work on new mirrors.
tim and amy
Beaverton Oregon
Posted: 05/11/12 04:43pm Link  |  Print  |  Notify Moderator
If you go to Fordforums or superduty forums there are step by step proceedures to upgrade your mirrors on the fords.
You can put the 99-07 mirrors on your SD withoug issues. The 08 up mirrors require some re-wiring to get all the funtions of "electrics" to work.
Meaning. On the newer mirrors they are electric out and fold, with electric adjustment and heat.
On my 03 it only has heat and adjust. So I would have to add switches and wiring to make the fold and extend to work.
If you don't want to put the Electric fold and extend, and only want the mirrors with Heat and adjust, it only requires splicing the wiring.
Honestly my 03 tow mirrors work just fine and plenty of view plus it has the built in convex mirror at the bottom. The convex mirror is manual adjust, but the upper is power with heat. You have to get out and push them in or out, but who really cares, it takes two seconds.
2012 Kodiak 300BHSL Ultimate with Fall Edition Package
2003 Ford Excursion V10
tim and amy
Beaverton Oregon
Posted: 05/11/12 04:46pm Link  |  Print  |  Notify Moderator
FYI, the mirrors you are looking at look exactly like my ford factory mirrors. Also,
the F250/350 with towing mirrors are dime a dozen in junk yards. They are most likely cheaper. But if his are new, that's a good deal.
