RV.Net Open Roads Forum: Class A Motorhomes: Winegard antenn vane
 > Winegard antenn vane
traveylin
Rockport
Posted: 05/09/12 07:34pm Link  |  Print  |  Notify Moderator
My vinegard tv antenna leading vane folded back and broke after only 18000 miles of wind resistance. I am in the process of ordering a replacement head but would like to know if this is a common failure. It is located alongside of the front a/c and is thus protected from overhead obstructions when in its travel position. If I had dummied up and left it in its upright position and fouled it I would expect the mast to be damaged not the vane just bent back. Any preventative measures would be useful info to not have a repeat. RV is a 2011 Georgetown 300
Old-Biscuit
Across the USA
Posted: 05/09/12 09:26pm Link  |  Print  |  Notify Moderator
I'm a thinking you might have not placed it in travel position and whacked a lower hanging tree branch that just clipped the vane.
Over 5 yrs. of FT'ng and haven't had any physical problem with mast/vanes etc. on our winegard antenna.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
ssocal
Highland SoCal
Posted: 05/09/12 09:27pm Link  |  Print  |  Notify Moderator
The same thing just happened to ours. We were between Needles and Barstow on I40 in very high winds. DW noticed a noise vibration on the road, we saw it was bent when we got home.
2011 Fleetwood Expedition 38B
2011 Grand Cherokee
2006 2500 Duramax 4x4
31' Rockwood
traveylin
Rockport
Posted: 05/10/12 02:30am Link  |  Print  |  Notify Moderator
I have been in very high headwinds, enough to trim the gas mileage rate considerably.. Another justification for staying off the road in windy conditions probably exist here
MNtundraRet
Bloomington, MN
Posted: 05/10/12 05:48am Link  |  Print  |  Notify Moderator
It sounds like the nut inside the crank has come loose. While you think the antenna is laying flat on the roof, it may actually raise due to the wind while driving. The loose nut does not allow the gearing to hold it down.
I have also noticed that some manufactures/dealers install the antenna wrong. The antenna lowers towards the front.
Mark & Jan "Old age & treachery win over youth & enthusiasm"
2003 Fleetwood Jamboree 29
shaman52
Georgia
Posted: 05/10/12 06:17am Link  |  Print  |  Notify Moderator
A very aerodynamic replacement would be the Jack antenna. It would not bend in high winds. It can mount on your Winegard windup arms. As good as the Winegard in VHF reception (majority of digital stations.) Maybe not quite as good in VHF reception. Here is a link. Jack Antenna Head
1995brave
San Antonio, TX
Posted: 05/10/12 06:48am Link  |  Print  |  Notify Moderator
You are wrong. Look at their manual when you crank it down it need to go down towards the rear of the RV.
MNtundraRet
Bloomington, MN
Posted: 05/10/12 08:03am Link  |  Print  |  Notify Moderator
1995brave wrote:
You misread my statment. The antenna is suposed to go down facing the rear. I have seen some going down facing forward which means they were installed wrong.
