RV.Net Open Roads Forum: Fifth-Wheels: Question! 6 - 8lug 16" wheels
 > Question! 6 - 8lug 16" wheels
Moonlighter48
Posted: 05/09/12 07:44pm Link  |  Print  |  Notify Moderator
OK, 2002 HR Presidential 36SKT, just upgraded to "G" rated tires, it has the OEM wheels which are 6 lug steel wheels, and Had the Original "E" rated tires on it when I bought it two months ago, the tread was real good, had some side wall cracking, I was hesitent about even taking it to the tire dealer to get tires put on, but it made it.
I just don't want to take a chance with those OEM 6lug wheels with 110Psi, they were Ok with 90Psi, but I didn't like it, so here is the problem, Spacers? 6 - 8lug?, or try to find drums that will fit with the same bearing size?, any Techs out there delt with this before or done this before?.
This trailer has the optional 7,000lb axles. I have looked and looked for 6lug rims that will go up to 110Psi, I can't find any.
Ron
45Ricochet
North Idaho
Posted: 05/09/12 08:07pm Link  |  Print  |  Notify Moderator
Lots of this don't make sense to me. Your tire dealer sold you G614 tires not knowing your wheel rating? Second thing is a 7k axle with six lugs? There is a reason you can't find 110 PSI wheels in a six lug pattern.
How much weight is on your axles? Many G614 owners don't run full pressure if it's not needed.
At any rate if your current wheels aren't rated to 110 PSI, don't put that much in as they will seperate. Usually stamped on the back side.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
wandering1
Posted: 05/09/12 08:08pm Link  |  Print  |  Notify Moderator
So who have you talked to?
HR
Golden_HVAC
Fulltime, CA, USA
Posted: 05/09/12 08:10pm Link  |  Print  |  Notify Moderator
I guess that you already bought the new 16" tires?
You might try Rickson truck, they make a few rims to upgrade from 16" to either 17.5 or 19.5" truck tires, that fit various rims that are on pickups and vans. Yet I can not think of any that have 6 lugs either. There is not enough space to make a 8 lug adapter while still has the 6 lugs in place.
Perhaps another source is ETrailer.com they sell both axles and upgrades to disk brakes - another upgrade worth looking into.
Fred.
Snow_King
Gold Canyon, AZ
Posted: 05/09/12 08:38pm Link  |  Print  |  Notify Moderator
Just air the tires to 80 pounds which is 3042 pounds on the inflation chart for that size tire. Question is are you approaching 12168 pounds on your axles?
Somewhere in a Fifth Wheel - Where it does not Snow
jimmyfred
Tx
Posted: 05/09/12 08:39pm Link  |  Print  |  Notify Moderator
............A 6 lug hub is normally a 5,200 lb. axle , 8 lug hubs with 6.5" spacing on 8 lugs can be 6,000 , 7,000 or 8,000 lb. axles ! I'd call the mfger and findout what brand of axles came on your trailer ! , jf
Ron
2003 Chevy 8.1 Dually 2Wdr.
1999 Travel Supreme , 33 RLSS
20K Reese , Prodigy etc.
Mile High
Denver, CO
Posted: 05/09/12 09:07pm Link  |  Print  |  Notify Moderator
X2 - something is not right and I think it is your axles are not 7K.
I got sold some G tires on the road after shredding my 4 factory tires on our 2003 with 6 lug. I never found any wheels that would take the 110psi. There just ain't no such thing. I had to settle for 80 psi
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
bkick
Bonita Springs Fl
Posted: 05/10/12 06:39am Link  |  Print  |  Notify Moderator
I am just changing from 6 lug 15 inch to 8 lug 16 inch rims. The only way is to change the brake drums, about $160.00 each, rims and good tires will add another $1500.00. Will also replace shoes and magnets again as have 40,000 on this set. That beats the heck our of replacing a tire or two on every trip we take. I'll have $3,000.00 in it and a better than new rig, I hope!! PM me if you need any other information I can give you.
Bkick
ExRocketScientist
Laurel, MD
Posted: 05/10/12 09:22am Link  |  Print  |  Notify Moderator
I agree that something doesn't sound right here. 6 lug wheels, IIRC only go up to about 3100 pounds. So they only cover up to 6K axles. Some 6K axles come with 8 lugs as an option. Once you get to 7K axles, it is strictly 8 lugs.
The OP may need to get new drums and new wheels both.
ERS
Snow_King
Gold Canyon, AZ
Posted: 05/10/12 09:53am Link  |  Print  |  Notify Moderator
He may not need anything but to set inflation to 80 pounds. What is his GAWR on the placard and what does it actually weigh?
* This post was edited 05/10/12 10:19am by Snow_King *
