wvabeer
West Virginia
Please delete
last
edited 05/15/12 06:21am by wvabeer *
View edit history
1992 Airstream 33'landyacht M/H
12 Arctic cat Wildcat
08 Arctic cat Thundercat
03 Kawasaki 650 Prarie
01 FLHTC
powderman426
ohio
Without a picture its hard to say, but swelling of particle board isn't a good thing. The rubber roofing should go over the edge of the roof and down behind the drip edge. It would be very difficult for water to travel up under it, so I would look for a leak in the rubber roofing. I would do whatever it takes to dry it out real good and if you can, coat the particle board with something to waterproof it. They make putty tape to go between the drip edge and the siding. I hope this helps. If you need to replace any of the particle board, they typically use 3/8" OSB material.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
dedmiston
Valencia
wvabeer wrote: I keep trying to insert a pic but it will not accept it.
See if this FAQ helps: Posting Pictures
Do you know the URL for the picture you're trying to post?
And if the photo is only on your local machine and not on a publicly accessible website yet, check out THIS POST for instructions for saving it to a site like Imgur.
2004.5 Dodge 2500 Diesel • 2005 Weekend Warrior FS2600 • Hooligan #3
Toys:
- 05 Yamaha WR450
- 07 Honda CRF250X
- 05 Honda CRF230
- 06 Honda CRF230
- 06 Yamaha TT-R90E
The Edmistons - Our Gallery
Never forget 9-11-01 Check out our blogs @ blog.rv.net
mapguy
Puget Sound
wvabeer wrote: I can see where the particle board under the rubber roof has swelled some on on side/corner and was wondering if I need to remove the whole side trim to reseal it? and what would I use? I keep trying to insert a pic but it will not accept it.
If the wood is swelling -it needs removed and replaced. Use a polyurethane based caulk for sealant. Depending on which sealant is used -bonding type or not, may need to use butyl tape or doubleside eternabond under trim. Use sealant on all screws.
Tend to think that potentially you can peel back the membrane enough to repair then use Eternabond sheet to patch membrane.
There is a great thread on a roof repair done to a Weekend Warrior trailer over at Glamis Dunes.com. You have to register to see pictures.
mapguy
Puget Sound
dedmiston wrote: wvabeer wrote: I keep trying to insert a pic but it will not accept it.
No insertin any type of media -document, picture or video.
You only can link to a "hosted" location that serves the media.
The instructions linked are pretty good.
wvabeer
West Virginia
All I can do to show you is go to photobucket look for wvabeer albums then go to new toyhauler and it will be the first 2 pictures. I am not sure why I can't post these pics
wvabeer
West Virginia
This is what I get
The connection was reset
The connection to the server was reset while the page was loading.
The site could be temporarily unavailable or too busy. Try again in a few
moments.
If you are unable to load any pages, check your computer's network
connection.
If your computer or network is protected by a firewall or proxy, make sure
that Firefox is permitted to access the Web.
Y-Guy
Tri-Cities, WA
Right now I don't think it's you I think the server has having tissy fits this afternoon. I've had a few challenges posting. Which portal are you coming through? RV.net? You might try woodalls.com they both link to the same server but sometimes the portals have issues.
Our RV: '07 Winnebago Sightseer 35J
Our Toys: Four Winns Horizon 190, Polaris Sportsman 500's & Honda Recon's
wvabeer
West Virginia
edited 05/11/12 10:26am by an administrator/moderator *
Y-Guy
Tri-Cities, WA
Yep RV.net is having issues with photos, I fixed so both photos would show on the first post and adjusted width to fit.
