RV.Net Open Roads Forum: General RVing Issues: Choose Drain Option
 > Choose Drain Option
BigSur2
Hampton, VA
Posted: 05/10/12 06:30am Link  |  Print  |  Notify Moderator
I had another thread that touched on this but wanted to put this question out front.
Can any of you provide feedback on draining your gray tank through a garden hose using something like this, i.e. sewer hose from black and running garden hose from gray to the fitting on the back of the elbow? Are there any flow issues using such a small hose?
90 deg elbow with hose fitting
OR do you think it would be easier and more efficient for me to go with 2 separate hoses and use one of these?
Y connector
Just not sure which will be more manageable and/or if it's worth messing with either. The main consideration for me is I'm never on extended trips, so my black usually lasts me the duration of the trip. I usually just switch over and then back again at dump time (separate drain lines).
* This post was edited 05/10/12 07:10am by BigSur2 *
BigSur2
2012 Keystone Bullet 286QBS
2006 Ford F150 5.4 V8
robatthelake
Vancouver Island
Posted: 05/10/12 06:55am Link  |  Print  |  Notify Moderator
Unless You are using a Macerator a regular Garden Hose should only be used to rinse out the various "Stinky Slinky" Components. Not used as a Drain.
That said I have seen People using Short lengths of Hose in some "Dry Camping" situations to empty their Grey Tanks into a "Blue Boy" or a Bucket to transport the liquid to a disposal site. Usually They had a Sewer Cap with a Hose adaptor, also sold at CW Etc.
Rob & Jean
98 Dutch Star Diesel Pusher ..92 Tracker 4X2
hershey
Albuquerque,(fulltime) NM, USA
Posted: 05/10/12 08:05am Link  |  Print  |  Notify Moderator
Sorry but there isn't any reason you can't use a plain garden hose for draining the gray tank.
Of course the black tank will require a sewer hose. An alternative method would be to use the Macerator, or Sewer Solution for both and use the same small hose.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
enblethen
Moses Lake, WA
Posted: 05/10/12 08:09am Link  |  Print  |  Notify Moderator
This is used to connect garden hose to rig.
T-1020
This Camco seal is used on the sewer inlet.
Camco 39322
It is common to use a garden hose for the grey tank. Some rigs don't even have a 3 inch outlet like in some pop ups.
Get at least a 5/8 inch diameter hose or even a 3/4 if you can find one. There could be small peices of food debris passing through the hose.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
Wherever I happen to park
Posted: 05/10/12 09:56am Link  |  Print  |  Notify Moderator
I have 3 tanks and a host of hoses. The black tank and the front gray tank drain via a common outlet and manifold. The rear "Wash water" Gray tank has it's own outlet.
So I have the following options:
3" hoses, using "Y" adapter
3" Hose for the front tanks, and a 25' GRAY 3/4" garden hose for the rear tank, this feeds the garden hose connector in the sewer adapter elbow or it can feed the "Y" adapter, I normally feed the elbow.
Macerator with 50' of BLACK 3/4" hose for any or all tanks (using 10ga extension cord for the rear tank) when needed.
WHat I use, depends on the site. All work well.
K3WE
Missouri
Posted: 05/10/12 07:24pm Link  |  Print  |  Notify Moderator
...because?
Happy Prospector
The Great Sonora Desert
Posted: 05/10/12 08:00pm Link  |  Print  |  Notify Moderator
I boondock most of the year and what I have used for years to drain my gray tanks are from right at the end of the trailer drain pipe I put on a clear sewer adapter then at the end of that I put a Termination Cap with a hose connection and for a hose I use a lay flat hose like this and I have never had a problem with this setup. It takes up very little for in the storage bay.
Kevin
Kevin
Retired, Fulltime RV'er
1999.5 F350 4X4 CC Diesel Flatbed
2007 Alpenlite Defender Toyhauler
2007 Yamaha Grizzly 700 (Green-It's your Daddy)
One Tough Kitty Named Bob
BigSur2
Hampton, VA
Posted: 05/13/12 06:08am Link  |  Print  |  Notify Moderator
Guys, does anyone know if I can use the 90 deg elbow w/ hose fitting in conjunction with a Rhinoflex hose?.....or is that not possible due to the types of fittings?
mobeewan
Hampton, Va
Posted: 05/15/12 01:24am Link  |  Print  |  Notify Moderator
I'm not familiar enough with what will work with Rhinoflex, but they do have their own version of the fitting you are asking about.
BigSur2
Hampton, VA
Posted: 05/15/12 04:44am Link  |  Print  |  Notify Moderator
I don't think that one has the garden hose fitting.
