RV.Net Open Roads Forum: Class A Motorhomes: Back Up Monitor
 > Back Up Monitor
Burfman
Phoenix, AZ
Posted: 05/10/12 10:53am Link  |  Print  |  Notify Moderator
I have a '99 CC with an Intec back-up camera and monitor. The monitor has failed and I am trying to find a replacement. I contacted Voyager and gave them the model # but they do not have a direct replacement. Have any of you run into this issue and if so how did you resolve it? The monitor is model CVM550 made by Intec. Thanks for any help.
Bill & CJ
'99 CC Allure
Enjoying it while we can!
BobR
Aurora, Illinois
Posted: 05/10/12 11:07am Link  |  Print  |  Notify Moderator
I had a Sony B/W monitor built into the dash. After not finding a replacement that would fit in the hole, I put a black plate behind the dash bezel and flat mounted the 5" color monitor from Rear View Safety. I spliced and soldered the old cable to the new instead of running a new cable.
Crazy Ray
Monroe,La
Posted: 05/10/12 11:14am Link  |  Print  |  Notify Moderator
Call RV Cams, they will help you out.JMO
RET ARMY 1980, DW Donna , "Tiny" (furkid) . Class A, 2007 Bounder 35E, Ford Chassis, 4 SAMS 6VOLTS,405W Solar,TriStar 45 Controller,1750W INVERTER, YAMAHA 2400, TOW: Honda CRV. READY BRAKE. "Living Our Dream". NASCAR FAN 14,18,20,11 LOVE CO & NM
Burfman
Phoenix, AZ
Posted: 05/10/12 11:26am Link  |  Print  |  Notify Moderator
Bob are you saying that the cable from the camera to the monitor is not coax but wires? If so did they provide a good schematic to make this easier or did you have to figure out by trial and error what wire went where?
Thanks
tomousecap
Wherever the Bounder is
Posted: 05/10/12 11:27am Link  |  Print  |  Notify Moderator
Check with these folks.
rvcams.com
Pretty helpful folks.
Bob
2007 Fleetwood Bounder - Full Paint 35E
Workhorse 6 Speed 496 Cubic Inch V8 - W22
Ford fans - RPM is a poor substitute for Cubic Inches!
2013 Chev Volt - Towing on a Master Tow Dolly
Gracie = Adopted longhair Amazon Chihuahua
Scavenger Power Exh. Installed.
BobR
Aurora, Illinois
Posted: 05/10/12 11:47am Link  |  Print  |  Notify Moderator
Bill,
Most of the wires were color coded the same. There were two wires that were not so I twisted together and tested first. Mine were wires, not coax.
* This post was edited 05/10/12 11:55am by BobR *
Burfman
Phoenix, AZ
Posted: 05/10/12 12:30pm Link  |  Print  |  Notify Moderator
Thanks for the tips. I tried RVCAMS but they couldn't help and all of the others I have tried are scratching their heads as well. I have an 8 pin connector and everybody is telling me it has to be a 12 pin. I guess the good thing is I can do all the checking on the internet and save myself a ton in gas.
viajante
Plumas Lake, CA, (near Yuba City) USA
Posted: 05/10/12 12:42pm Link  |  Print  |  Notify Moderator
rvcams.com
X2
When my factory installed monitor died, it was no longer available. The folks ar rvcams.com found a replacement model and even had all of the adapters and a trim piece to make it work. Great folks to work with.
Dave & Brenda
Shadow (Sheltie), and Zoe (Shih Tzu)Faithful Companions
2008 Itasca Sunrise 35L
ets1996
tumwater,wa.
Posted: 05/10/12 01:30pm Link  |  Print  |  Notify Moderator
Try to GOOGLE Quality Mobile Video they have a lot of components and system and the had good tech support when I called for install and operation of a system I got from them
fcooper
Richmond Hill, Georgia
Posted: 05/10/12 09:42pm Link  |  Print  |  Notify Moderator
About two years ago, I had the same problem (Intec monitor) on my Holiday Rambler. I have PDF document with explanations and pictures of how I replaced the monitor and camera with a 7 inch lcd monitor and two cameras (close up and distant view) on rear of coach. If you want a copy, send me an email address via PM.
The Intec monitor will not simply slide out through the hole in the dash. It is larger than the opening, and must be removed from under the dash. It weighs about the same as a tube type 13 inch tv.
The Intec system uses a 6 pin cable, and the replacement LCD system only needs 4 pins, so it is possible to adapt the old cable to work with a new monitor and camera.
Fred
Fred & Vicki
Richmond Hill, Ga
2000 Holiday Rambler Endeavor/Freightliner/330 Cat
2000 Honda Odyssey toad w SMI Silent Partner braking system
Tire Sentry monitoring system
 > Back Up Monitor
