RV.Net Open Roads Forum: Travel Trailers: Unhook or not
 > Unhook or not
CakeHenn
Temple, TX
Posted: 05/10/12 11:32am Link  |  Print  |  Notify Moderator
So I've got to say hooking and unhooking my TT with the Weight Distribution Hitch and just the ball in general is a PITA! So on most of the little trips we have gone on I don't even bother unhooking my truck. I just let the weight off it a bit and it's normally fairly level. Other than if I'm in a spot where I can't stay hooked up or it's so unlevel that I need to unhook are there other reasons why I should unhook assuming I'm not planning on driving anywhere?
Also why is my hitch so hard to get on and off. I know how to work it but it just seems stiff...should I lube it with WD40 or something? It seems it's harder to unhook than hook on. The WDH is fine getting on just a process and I have to be on level ground or it can be hard.
Since Jan when we got the TT we have now spent 9 nights in it and those were all 1 or 2 nights trips at a time. Me and the family are having a ball and I've learned so much partly due to this forum so thanks.
TT: 2013 Jayco Eagle 314
Truck: 2006 GMC 2500HD Duramax
Duck Gun: Benelli Super Black Eagle II
dodge guy
Bartlett IL
Posted: 05/10/12 11:35am Link  |  Print  |  Notify Moderator
Nothing wrong with not unhooking. I do it when I can. if I can`t get level front to back because of it, then I unhook. as for getting the hitch off the ball....are you using some type of lube on the ball and hitch mechanism? lube up the ball, I use wheel bearing grease, and a small daub on the locking mechanism. also be sure to use some grease on the WD bar pivot points on the hitch head.
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
weathershak
Not sure, I need to look out the window
Posted: 05/10/12 11:37am Link  |  Print  |  Notify Moderator
We used to do it all the time on one nighter trips. Not a problem if the site is level enough. We used to disconnect the trailer wire connecter though, force of habit. Its ok to lube the ball and tongue.
Full timing it since July 2012 My pics
BarneyS
S.E. Lower Michigan
Posted: 05/10/12 11:41am Link  |  Print  |  Notify Moderator
You should use grease on the ball and where the WD bars insert into the hitch head.
When you park in your spot, you should chock the tires and then proceed to unhook from the truck. Often it might be necessary to inch forward or back a bit with the truck to relieve the pressure of the backing process on the coupler. This will most likely let the ball release from the coupler. It is possible that your coupler needs adjustment but not likely. Try the lube and moving the truck a bit to see what happens.
If you have only camped 9 nights so far, that means you have only hitched up and unhitched a few times. It really should not be a PITA to hook up and unhook. There is a bit of a learning curve and it will get easier as time goes on.
There is nothing wrong with leaving the truck attached if you wish. If the site is big enough to do it, you can get the trailer level, and you don't need the truck for anything else, then go for it.
Barney
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
morley
British Columbia
Posted: 05/10/12 11:52am Link  |  Print  |  Notify Moderator
X2 for unhooking the power connection from the tow vehicle just so that you don't accidentialy pull down the tow vehicle battery.
2008 Topaz F254SS 26 ft.
2009 Chevy Silverado, 2500HD, Duramax, Allison Tranny, 4x4, EC
Honda EUi2000
bid_time
Michigan
Posted: 05/10/12 12:29pm Link  |  Print  |  Notify Moderator
Are you saying the hitch is to hard to get off the ball? There should be an adjusting screw on the underside of the hitch which you can loosen a little to make it come off the ball easier.
CakeHenn
Temple, TX
Posted: 05/10/12 12:44pm Link  |  Print  |  Notify Moderator
Yes....I'll take a look.
CakeHenn
Temple, TX
Posted: 05/10/12 12:54pm Link  |  Print  |  Notify Moderator
Barney
Two trips have been 2 nights the rest are all one nights...so 7 outings. And yeah I'm normally unhooking and hooking it all alone so it is kind of a PITA. Not hard but takes time...when I get to the camp site the sooner I can finish the work part the better. We have 2 little girls ages 2 and 4 so if I can save 10 minutes of work and get to them faster it just makes life easier.
APT
SE Michigan
Posted: 05/10/12 12:57pm Link  |  Print  |  Notify Moderator
It is easier to remove the WD bars when the jack is lowered, raising the rear of the truck somewhat, back to near unloaded height. This is a lot easier to do with an electric tongue jack.
2012 VW Passat TDI
bid_time
Michigan
Posted: 05/10/12 01:01pm Link  |  Print  |  Notify Moderator
It's up inside the coupler, you'll have to lay on the ground and look right up into where the ball goes and it's on the back side of the latch that engages the underside of the ball. Close the coupler before crawling underneath to see the adjustment on latch.
 > Unhook or not
