LongWeekends
Scottsdale, AZ
Hey All,
I bought a Genturi set up a while back and I am just now getting around the getting it set up. I am going to assume that most of you that use Genturi or any similar set-up are not riveting the strap mounts into the side of your RV. I have no interest in doing so.
So how did you secure it? Suction cups on the window somehow? Find something on the roof to secure it to? Any ideas? If you have any pics, I would love to see them.
Thanks in advance!
Michael
Just me, my wife, our 11 year old daughter and our two big, hairy Goldens.
2004 Coachmen Cross Country
370DS - 300HP - 2 Slides
PatrickA51
Lost
LongWeekends wrote: Hey All,
Thanks in advance!
I use a set of these, more trouble than they are worth. Use the mounting pieces that came with the Genturi Look here
Jim@HiTek
Gresham, OR, USA
Many use dual suction devices but I have read where the heavy duty types can leave marks. When I tried it with fairly cheap, handle operated suction clamps they would pop off after a couple hours of use. Annoying.
Hopefully, someone has a better idea.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5' with 50HP LP boost.
Black Rock Lava Park, Nevada
rv2go
Fulltime (Knoxville, TN).... or someplace else
I use this that I got from Harbor Fright. You may have to use it on glass if your RV side is not real smooth.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
www.rv2go.us
I'm here #4335
Travel Photos
Deetour
Washington
Simply put a little clip on the pipe where it meets the RV's gutter and attach it/hook it to the gutter.
The clippy thingy attaches and stays with the Genturi pipe. No need to fool around with those suction cup gizmo's.
LongWeekends
Scottsdale, AZ
rv2go wrote: I use this that I got from Harbor Fright. You may have to use it on glass if your RV side is not real smooth.
How long does it hold? Do you need to check on it every couple of hours?
M GO BLUE
Southgate, MI
I use the 3-inch suction cups (the kind with the fold down hooks) and get them from Walmart...I usua;;y have to replace one every 2-3 years because it pops off going down the raod but for the most part they start where I put them...and at less than $4.00 per usction cup no big deal...
Better than putting rivets, sticky tape, etc. on the side of the fifth wheel...
edited 05/10/12 01:10pm by M GO BLUE *
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
bradl
Portland, OR
Mine came with very strong double-sticky tape (in addition and as an alternative to rivets).
Brad L., 2012 Itasca Sunova 30A
RognBon
Roseville, Calif.
Posted By: bradl on 05/10/12 11:41am wrote: Mine came with very strong double-sticky tape (in addition and as an alternative to rivets).
Same here. I have used these for over two years with no issues.
RognBon
1997 Monaco Dynasty 40'
Cummins 8.3 325 HP
2008 Ford Edge Toad
Weathertodd221
FL
got a bathroom grab handle from lowes for $6. Worked continuously through 4 days of running. Lil dab of water before you stick it!
