chimeraxp
calgary
OK the PO "repaired" the rear section of the trailer but a nightmare is what is really is ....could be worse .
The rear section has a single large window under this he sheeted the lower section of the trailer with plywood (33"x84"). leaving it exposed to the weather . looking around seems the lower framing is all removed , he had the sheet screwed in to the benchs and corner framing.
after opening the inside I found bother corners rotted almost floor to ceiling .
Yesterday I opened everything up out side . replacing the two corners.
Now I think it would be best for me to re-frame the back , removing the sheet of plywood and tin the out side ..
so anyone have some pictures showing the framing of the rear with a single window .
Once I figure out how to post pictures I'll upload what I can.
Gene&Ginny
North Kingstown, RI
It may be helpfull to know what brand, model, year trailer you have. I don't think all manufacturers build things the same way.
Gene and DW Ginny
2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
chimeraxp
calgary
Gene&Ginny wrote: It may be helpfull to know what brand, model, year trailer you have. I don't think all manufacturers build things the same way.
leaning towards Tripe E unsure on what year .
been having a hard time all day posting . will try and get pictures uploaded later
Gene&Ginny
North Kingstown, RI
Here is a picture from a fellow Sunline owner when he rebuilt the rear of his unit. If all you had in the back was a sheet of plywood then you may have to design your own "rebuild". Some framing is hard to see with the insulation. His rebuild was mostly under the window where there is no insulation in the picture.
chimeraxp
calgary
thanks for the post , a good picture too ! should help me out a lot .
hilandfrog
Montana
NOT trying to pimp a thread but.....
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25467063/srt/pa/pging/1/page/3.cfm
lots of pics....
Good luck
Repo
05 Tundra 4x4
1976' SIX PAC, cut to size and function.
$800 1977' Road Ranger, not yet road worthy (AUG '11')
Downwindtracker2
BC
I haven't tackled a TT,just a tent trailer,new roof,front and floor. There are a couple of tools for putting it back together that are really handy, Kreg pocket hole jig,Lee Valley or KMS and a narrow crown air stapler,Princess Auto or KMS. Good luck.
Adventure before dementia
chimeraxp
calgary
Try this , more or less the current state .
thanks for the link too
Gene&Ginny
North Kingstown, RI
hilandfrog wrote: NOT trying to pimp a thread but.....
lots of pics....
xxx
Good luck
Repo
Yes, that is a good thread and some great pictures, deserves to be a "clicky".
http://www.rv.net/forum/index.cfm/fuseac........d/tid/25467063/srt/pa/pging/1/page/3.cfm
Gene&Ginny
North Kingstown, RI
chimeraxp, looks like you have quite a project ahead of you. Good luck on the rebuild.
