RV.Net Open Roads Forum: Dinghy Towing: Any good ideas for mounting electrical connector
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  General Topics
 > Any good ideas for mounting electrical connector
PT-RVr
Washington
Posted: 05/10/12 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2012 Jeep Wrangler which will hopefully be entering "Dinghy" status soon. The tow bar mounts are installed and all of the wiring for lights brakes ect. have been run to the front of the vehicle. Unfortunately I am struggling with where to mount the connector on the front of the jeep to plug into from the motor home. The bumper is partially covered with the air deflector. Even if the air deflector was out of the way, the connector would have to be mounted pretty far back under the bumper to achieve an adequate mounting surface. Any Jeep owners a good mounting solution? Anything better than the standard 5 pin connector that came with the tow bar? Thanks.
Part-Time-RVr
1 Wonderfully Fantastic Wife
2 Really Great Kids
1 Crazy Black & Tan Cocker Spaniel
2011 Sunseeker 2860DS 6.8L Triton V-10
2012 Jeep Wrangler
tx_maniac
Allen, TX
Posted: 09/22/12 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
I was looking for some product information on tow bar deflectors and came across your post. You've probably already dealt with this, but does the MH have a 5 pin connector on the back or the more standard 7 pin? The other two pins support trailer brakes, but I used them to wire in a US Gear auxiliary braking system. I use a standard 7 pin coiled wiring cable that stretches and retracts. If you don't have an auxiliary braking system, you just don't use those two pins on your toad. But it's already there if you decide to add later. Some states require auxiliary braking especially in mountainous areas. The toad connector is just screwed to some metal support in the front engine area down low.
Mike and Joanne Patrick
2011 Thor Tuscany 40LX DP
2007 Jeep Wrangler Sahara Unlimited
