RV.Net Open Roads Forum: Fifth-Wheels: Air hitch or air pin box?
 > Air hitch or air pin box?
rsg63
Dublin, Ca.
Posted: 05/11/12 11:13am Link  |  Quote  |  Print  |  Notify Moderator
We have the 5th Airborne pinbox on our 40' TH. It works well (maybe reduced the negative ride by 20-25%) but to be honest if I had the chance to do it again, I'd get the Trailer Saver by Hensley. I rode in a truck that had this setup with our trailer and the difference was noticeable. Just a seat-of-the-pants feeling would say the reduction was about 50% of negative ride effects. They aren't cheap however, but I feel it's a worthwhile investment if you tow more than a few times a year.
08 Jayco Recon ZX 40' 3 axle T/H, dual A/C, 2006 RAM 3500 Cummins Dually, Pac Brake, Banks CAI, Monster Exhaust, 3.5" RAM intake, 51 Gal aux tank w/ tool box, 265/70/17 Goodyear Wrangler SA Pro Grades, Reese Sig series 24K hitch. DVD/NAV/Backup Camera.
brewen
Southern Alberta
Posted: 05/11/12 11:52am Link  |  Quote  |  Print  |  Notify Moderator
We're on our 2nd Trailersaver, just installed (by me). The first was mounted on our Volvo 770 HDT (which we recently parted company with...sadly) and we now have a brand new TS3 mounted on standard Reese rails. (We had originally planned to install one of the new Reese 20K hitches but when they were late coming in we decided to go back to the TS3 and are glad we did.) The new TS3 will definitely be with us for a looooooong time as it fits most standard rail setups. If we DID decide to change to a new truck at some time in the future, changeover is really simple. The only hiccup would be switching the air line and electrical from the 'old' cab to the 'new' cab. Or, I always have the option of just running it off the onboard compressor plugged into the trailer hookup. Personally, I prefer having the air gauge and compressor switch in the cab where I can see it.
We took the new hitchup for it's first test run yesterday, and love it, as expected. Now, we can hardly wait for our first of many trips this summer!!
Oh yeah, almost forgot to mention....if I want it out? Four pins and a crowbar to lift it enough to get a couple of 2X4's under it and it slides to the back of the truck to a couple of sawhorses or ??? and it's out, leaving the bed clean for whatever. Not that that will happen too often. That's OUR way to go...yours may be different.
2003 Ford F350 7.3 Powerstroke. 4:10 CC Dually, Edge Evolution chip, TS3 air ride hitch.
33' Alpenlite & 5 decades of happy RV'ing
"I tried a lot of different things in my life, before I found my true vocation: RETIREMENT!!
Sandy & Shirley
North East, MD
Posted: 05/11/12 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
We have the Trail Air pin and center point suspension. The combo work great together. We've accidently left a glass of water on the table, drove home, and it was still there when we got home!
'02 F350 7.3PSD CC LB DRW, Reese 20K Hitch, Brake Smart, AirLift, C-betr mirrors,
'04 Everest 343L, TrailAir, RotoChoks, Wayne's stabilizer
Toys: Fold-Away Pet Carrier, Thermos Grill 2 GO
For more info, visit Our RV web site.
silverback31b2
Upstate NY
Posted: 05/11/12 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the info.
Chevman, what brand is your air hitch? I can not seem to google a Reese air hitch.
2011 Silverback 31B2
2011 F350 Superduty, Crew Cab, 8' box, 4x4, 6.7 PSD, Lariat, Loaded
BD3 Trailersaver air hitch
Tire minder TPMS
dhayes
Maine
Posted: 05/11/12 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
We have an air pin box and it was, in our opinions, a giant waste of $$. Our ride did not improve at all, even after weeks of fussing with inflation levels. I would never buy one again. MaineDon
okiejoe
Oklahoma City
Posted: 05/11/12 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
I have Both, Trailersaver air hitch & MorRyde Pin box, maybe a little overkill but I love it and worth every dime.
The Black Pearl
Ottawa
I have the Sidewider pin box with the air ride hitch. I rode fine last year and ride will be better this year since the frame was modified to fit the tow vehicle better (level now). Hitch usually gets place less than the trailer so that is why I went with this set up.
2010 F-150 XLT-XTR - Max Tow
2011 KZ Durango 305BH
Husky Airbox Revolution 16K Hitch
Teddy Rufus (Standard Schnauzer)May 8, 2010
Top Pop Rails -3 bikes
mobilcastle
OH
Posted: 05/12/12 06:05am Link  |  Quote  |  Print  |  Notify Moderator
I have a Mor/Ryde pin box and Equa-Flex suspension-works great. I use a B&W hitch-easy to remove to flat bed and extremely easy to hook up or disconnect. Hitch will only handle 18K.
2010 Heartland 3670RL Demco,dual panes,2-AC,
7000lb axles,G rated LT tires,38' high profile,
2011 Chevy 3500HD,Dually,D/A,LB,EB,4X4,
B&W Companion,GVWR-13,000
larry barnhart
wenatchee. wa usa
Posted: 05/12/12 08:36am Link  |  Quote  |  Print  |  Notify Moderator
We have the easyrider airhitch. the reese part of it is the bed rails and the 20K head so it is an easyrider/reese. the easyrider lost out a few years ago from another air hitch company that was not building illegal products because of a patent issue. I would buy the trailersaver if we needed to purchase another airhitch because they fit the reese bed rails. Air is awesome,
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
bigdon68
Churchville, Maryland
Posted: 05/12/12 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
I have an AIR SAFE hitch and Mor Ryde IS Suspension. The ride is fantastic and the hitch has been great. Have had the hitch now for 6 years without a problem.
You pay more for an Air hitch but you always pay more for quality.
Enjoy.
bigdon68
2008 F350 CC 2WD LB 6.4 Lariat Auto SRW, Retrax, AirSafe Hitch, CB, Train Horns, On-Board air, RideRites, Aux Tank
2007 Ameri-Camp SummitRidge Reserve,40ft, Onan, MorRyde IS, Disc Brakes,17.5 Alcoa Wheels, Michelins, dual AC, Bigfoot Levelers
MY PICTURES
