David0725
I posted many times before that I had something clicking when I go to start the rv! And this is what I found its a ALLISON TRANSMISSION VIM MODULE # 29509886, 12V, 6R.. I see them on ebay. but I still dont no what it does! And If I should replace it or not. I all I no is its taking longer to get the click before it starts. And if I dont click it wont start. some times it takes like 5 0r 10min And if I do replace it do I need codes or what?
edited 05/11/12 10:06am by David0725 *
1994 Holiday Rambler Imperial DP
1999 Honda Accord V6 Toad
2bzy2c
California
English?
I have no idea what you are asking.
My advice is worth exactly what you paid for it.
gbopp
The Keystone State
David0725 wrote: ALLISON TRANSMISSION VIM MODULE # 29509886, 12V, 6R.. I see them on ebay. but I still dont no what it does! And If I should replace it.I just no that its taking longer to get the click. And if I dont it wont start. some times like 5 0r 10min And if I do replace it do I need codes or what?
If no one gives you an answer, you should take it to a shop that works on Allison transmissions. Apparently you have a problem.
Dog Trainer
Richmond Mi.
You need to explain the problem and your request here. No one will have an idea of how to be of assistance with what you have written without a statement of the problem you are having.
93 Airstream 35' Dp
5.9 230 uprated to 300 HP
Allison MD 3060
Dutchess and Shadow Golden's Daktari Cavalier King Charles (fur Bearing Children)
past-MIdirector
Michigan
Contact Allison or a dealer for the information on the module. They're the ones that will have the information your asking. Allison has pretty tight controls on it's soft wear and parts. The Allison transmissions dealers are the only ones who can clear and check codes since they have all the soft wear.
rexabbot
Cumming GA
Mine wouldn't go into gear because of a bad exhaust break. There are several things that feed into the vim such as idle speed.
If all conditions are not right it won't go into gear to protect the transmission.
There is a good chance it is not the VIM.
You need to take it to a authorized Allison repair faculty.
bluwtr49
Green Valley, AZ
I read the OP 3 times and still have no idea what is being dicussed.
Dick
2000 40" DP Beaver Patriot Thunder Cat C-12 425 HP, 1550 Tq
1997 Jeep GC Limited ---toad
2008 Toyota Tundra Crew Max Limited TRD (Retired)
2009 Cougar 268 RLS ~8700 lbs road wt (Retrired)
2006 Jeep Liberty Turbo Diesel.....TV in Training
ScottG
Bothell Wa.
All the fancy new phones out there are making Americans devoid of writing skills. We look like lazy idiots to the rest of the world.
Dang I'm getting cantankerous..
edited 05/11/12 08:00am by ScottG *
Scott, Grace and Wesly
H0NDA eu2000i
Travelon
Sierra Nevada Foothills, CA
Describe the sound it makes then we can help.
2004 Silverado 2500HD D/A CC LB 4x4, Timbrens, Fold-a-Cover,
Line-X, DeeZee Running Boards, Prodigy, Husky 16K UBS,
2004 Titanium 32E37DS, Two Honda EU2000i
fla-gypsy
North Florida
He is waiting for a control module to engage to start. While I have no first hand knowledge of this issue, I have seen it discussed. Apparently the control module is waiting for some input/feedback circuit which when received engages with a clicking sound and allows the unit to start up and is unique to Allison transmission units.
