RV.Net Open Roads Forum: Help suburban sw6de runs out of hot water very quick
 > Help suburban sw6de runs out of hot water very quick
stang233
olympia
Posted: 05/10/12 11:56pm Link  |  Print  |  Notify Moderator
I have the Suburban SW6DE and it heats the water up just fine but I only get about 80 seconds of hot water then its cold. I know its only 6 gallons but if I base the flow on the cold water it takes about 50 seconds to make a gallon so I should have around 5 min of hot water. I checked the bybass going into the cold and it is completely open. Any ides? I am very confused. Richard
I believe my system only has a single bypass valve. I pulled the cover inside the RV and the only valve I see is direclty before the T of the cold and hot input. I saw others mention a check valve that fails. Can i just replace the bypass valve or can it be cleaned. I will try and get some pictures up. Thanks Richard
* This post was edited 05/11/12 11:16pm by an administrator/moderator *
Old-Biscuit
Across the USA
Posted: 05/11/12 12:12am Link  |  Print  |  Notify Moderator
Yes you have a 1 valve (2 position) system with check valve in hot water out.
Your picture shows valve in correct position for normal use (handle parallel with line) allowing cold water to go in water heater and come out top hot water out.
(When you turn valve so handle is perpendicular and parallel with line that ties hot/cold together that is bypassing water heater.....no water goes in cold inlet and check valve on hot outlet stops water from back flowing into water heater thru hot outlet.)
From your description sounds like the valve is NOT closing off the bypass side and cold water is flowing thru bypass line mixing with the hot out (maybe even closing the check valve so that nothing but cold flow is flowing).
Heat the water..then open hot side on closest faucet....then change the position of valve several times and see if it improves hot water flow (valve may have debris in valve seat stopping it from sealing off). No improvement.....
Then remove valve and inspect/clean IF you can see anything that is obvious.........otherwise get a new valve. (You will need to drain water heater before removing valve......time for a drain/flush anyway)
Good luck....
* This post was last edited 05/11/12 11:18pm by an administrator/moderator *   View edit history
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
Golden_HVAC
Fulltime, CA, USA
Posted: 05/11/12 12:15am Link  |  Print  |  Notify Moderator
Hi,
There is supposed to be a tube that goes to the bottom of the hot water tank.
So the fresh water going in should go to the bottom, then not mix with the outgoing hot water. Then as the cold dense water flows in, it should be staying at the very bottom, until it heats up, and not mix with the lighter weight hot water.
Many water heaters use a plastic tube to carry that hot water to the bottom of the tank. Home water heaters even have a warning to not use more than 110F inlet water.
My guess is you might have a broken water inlet tube, you have all the symptoms.
Fred.
Old-Biscuit
Across the USA
Posted: 05/11/12 12:48am Link  |  Print  |  Notify Moderator
Golden_HVAC wrote:
Hi,
Fred.
YES........that would explain the sudden change in water temp.
Broken dip tube........duh
CavemanCharlie
Storden,MN
Posted: 05/11/12 06:35am Link  |  Print  |  Notify Moderator
Ya, but home water heaters have both lines coming into the top of the tank so a dip tube is needed. But, on camper water heaters, like the one shown in the pictures, the cold water inlet is in the bottom of a tank . So, do they have a dip tube?? I'm thinking probley not. (But, I've broken one apart to look)
jerem0621
Sequatchie, TN
Posted: 05/11/12 06:44am Link  |  Print  |  Notify Moderator
My buddy had the exact same issue with his camper earlier this year. It was a bypass valve. I would double check them again.
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
powderman426
ohio
Posted: 05/11/12 08:48am Link  |  Print  |  Notify Moderator
Take those crappy check valves out and throw them away. Problem solved. Every place there is a check valve gets replaced with a manual valve and then you will know for sure when a line is open or closed. I did mine after having a similar problem and now all is good.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
skipnchar
Topeka or somewhere else
Posted: 05/11/12 09:13am Link  |  Print  |  Notify Moderator
yOU SAID THAT YOUR "BY=PASS" was completely open. it SHOULD be completely CLOSED when being used. Open is only for when the water heater is bypassed for winter use and allows cold water to enter the hot water lines to enable pumping antifreeze through the system. If you have a single valve system it should be an "either/or" type of valve where the two positions can allow water to go to either the bypass or the inlet. Unless this valve is bad you might just check the dog shower to be sure both faucets are completely closed.
SilnJohn
Denver
Posted: 05/11/12 09:54am Link  |  Print  |  Notify Moderator
X2 on what skip said, if the valves are correct check the outside shower to make sure the faucets are completely off.
2012 Toyota Tundra Crew max 5.7 Limited
2005 F150 Lariat 4x 5.4L, 3.73 (80K mi 4sale cheap needs.......work)
2003 Nissan Pathfinder
2012 Shadow Cruiser 260BHS
stang233
olympia
Posted: 05/11/12 11:23am Link  |  Print  |  Notify Moderator
Skip can you review the picture and tell me if the valve is correct
