RV.Net Open Roads Forum: Will the trailer drain my tow vehicle battery?
 > Will the trailer drain my tow vehicle battery?
skipnchar
Topeka or somewhere else
Posted: 05/11/12 01:15pm Link  |  Print  |  Notify Moderator
Yes unless you disconnect it. Ford and Toyota use isolator relays, Dodge and GM are only fused so hot all the time.
martipr
Haltom City, Texas
Posted: 05/12/12 09:06pm Link  |  Print  |  Notify Moderator
Some say Dodge has a relay, others say only Ford and Tundra. In this instance "enblethen" and "skipnchar" posted opposing statements just one hour apart. Someone has to be wrong. It would sure be nice if people who don't know would not post.
Old Navy Chief (AOC) Retired Aircraft Mechanic/Inspector
2007 29' 27FBV Trail Bay V Series
2007 Dodge Ram 1500 Mega Cab 5.7 V8 3.92 Rear End
Reese Strait-Line Dual Cam Hitch
organizedmayhem
North East,MD
Posted: 05/12/12 09:19pm Link  |  Print  |  Notify Moderator
I can tell you a 2012 Ram is hot all the time.
enblethen
Moses Lake, WA
Posted: 05/13/12 06:54am Link  |  Print  |  Notify Moderator
I have seen some Dodges with relays and others without.
Martipr: look under the hood on the driver's side wheel well in the fuse and relay box. It will physically tell you whether you have relay controlling trailer power.
Fords have relays.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
TenOC
On the road -- Full time
Posted: 05/13/12 08:52am Link  |  Print  |  Notify Moderator
I THINK that my 2006 Dodge 2500 Ram Diesel is NOT hot all the time. I have tested it with a test light. However, I always unplug the trailer (and the GPS etc.)if I am stopping overnight with the trailer connected to the Ram. I sleep better not think about if it is hot or not.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
ExRocketScientist
Laurel, MD
Posted: 05/13/12 02:54pm Link  |  Print  |  Notify Moderator
bob213 wrote:
If it's the truck in your signature, it will draw from the truck battery. Fords don't let that happen unless the key is on. It shouldn't be a problem for one night. It will charge as you drive, but will take many miles to recharge your trailer battery. I always unhook the umbilical cord if I stay hooked up just to be safe.
X2. Some people with GMs that had alternator/battery issues actually charged their truck battery with the converter in the trailer overnight at a campground with hookups by leaving it plugged in overnight. I have played with my Ford using a meter and as soon as the key is turned off, that's it on that pin in the connector.
As for charging while driving . . . not much. I towed my TT home 2.5 hours and plugged it in here at the house. It still took an hour and a half for the charger to get to the float stage on my batteries.
ERS
