RV.Net Open Roads Forum: Will the trailer drain my tow vehicle battery?
 > Will the trailer drain my tow vehicle battery?
SkyPiGG
Southeastern PA
Posted: 05/11/12 08:55am Link  |  Print  |  Notify Moderator
We are leaving later today for a trip, but I have the trailer hooked up to my truck already. Since the TT battery was low from sitting in storage for a few weeks, is there a danger of the TT draining my tow vehicle battery? I have the factory tow-package.
Thanks!
SkyPiGG
2011 Keystone Cougar XLite 26BHS
2011 Silverado LT 1500 Crew Cab 5.3 V8 HD 3.42 (King George)
Fastway E2 10k Hitch
coolbreeze01
Redding, Ca
Posted: 05/11/12 09:02am Link  |  Print  |  Notify Moderator
Probably not in just a few hours, but if possible I would plug the TT in and let it charge.
Definitely check the water in your batteries and add distilled water as needed. Have fun.
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
JKQ
Posted: 05/11/12 09:03am Link  |  Print  |  Notify Moderator
If your TT battery were to go dead, then the trailer would draw from your truck battery. Once the truck is running both will charge.
2013 CruiserRv Enterra 314 RES TT, 36ft, 3 slides
2013 Ford F250 Crew Cab Power Stroke Diesel 4x4
Reese WD hitch with dual friction control bars
Dometic 3000 KW portable genset
bob213
Fresno, CA
Posted: 05/11/12 09:13am Link  |  Print  |  Notify Moderator
If it's the truck in your signature, it will draw from the truck battery. Fords don't let that happen unless the key is on. It shouldn't be a problem for one night. It will charge as you drive, but will take many miles to recharge your trailer battery. I always unhook the umbilical cord if I stay hooked up just to be safe.
enblethen
Moses Lake, WA
Some TVs have a relay to isolate the trailer from it. You would need to verify on your rig that it is equipped with one. If it doesn't have a relay the trailer battery will try to equalize with the TV's battery.
I would suggest unplugging from the TV until you determine wwhether you have a relay or some type of solid state isolator.
I would suggest a relay over a diode based isolator.
battery disconnect relay wiring
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
reno82
Cardiff by the Sea, CA
Posted: 05/11/12 09:27am Link  |  Print  |  Notify Moderator
I was under the impression new Chevy's had a 10 min shut off of battery drain to keep you from running it down. I know everything else in the truck will shut off after this amount of time including the Acc plugs, not sure on the trailer plug.
ScottG
Bothell Wa.
Posted: 05/11/12 09:47am Link  |  Print  |  Notify Moderator
Not at the trailer connection ~ it's always hot.
Scott, Grace and Wesly
H0NDA eu2000i
SkyPiGG
Southeastern PA
Posted: 05/11/12 11:37am Link  |  Print  |  Notify Moderator
Thanks for the responses. I unplugged the TT from the truck just to be safe.
RoyB
King George, VA
Posted: 05/11/12 11:46am Link  |  Print  |  Notify Moderator
My ford 2010 F150 will disconnect the trailer battery connection after a few minutes of turning off the ingition key. When driving my trailer battery will receive a charge from the truck alternator system. Not all trucks will do this and some are always on... My truck start battery is safe from being run down by the trailer connection. When on the alternator system will charge both battery systems when the ingition key is off the truck will disconnect from the trailer battery system.
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
enblethen
Moses Lake, WA
Posted: 05/11/12 12:15pm Link  |  Print  |  Notify Moderator
Most late model Fords and Dodges have relays.
GM products normally do not have isolation.
