cm11599ps
Long Island
Any idea how long it takes for poop to break down in our tanks?
downtheroad
Pacific Northwest
Not sure it does "break down." These are holding tanks, not septic tanks with drain fields.
Break down is a result of enzymes.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
Deb and Ed M
SW MI, USA
Why does it need to "break down"? - your tanks are a holding facility - NOT a septic tank. Personally, I'd rather dump at the campground, even if things are still "whole" - than go driving down the road with a full black tank, trying to make like a macerator.....
dieharder
Ottawa, ON
cm11599ps wrote: Any idea how long it takes for poop to break down in our tanks?
Quick answer - longer than it should stay in your tanks.
1999 Itasca Sunrise
garyhaupt
Back living in Kitimat..northern BC.
i think maybe you don't have the needed info..you need to have maybe 5/7/10 gallons of water IN the tank, before you start the camping thing. Then, all the 'material' becomes liquid. Prior to actual dumping, use the rinse access to put more water in..adds to the volume and thus pressure, eh...and then, when you pull the handle? whhhoooooosh...it all just flushes out. Then you do a couple more close, fill, open..just to clean out the bits. Done deal. I always leave the dump station with water IN the tanks. Even if being parked for a week or two...keep residual stuff from drying and caking.THIS you do not want. Not Ever.
Gary Haupt
I have a Blog..about stuff, some of which is RV'ing.
http://mrgwh.blogspot.ca/
cm11599ps
Long Island
I thought that the chemicals you put in broke down the poop into a liquid.
ecoast
NW NJ's Highlands
drive a few miles and it'll all be liquid...
07 5.9 CTD & 2000 Northstar Laredo TC towing 87 Samurai ORV on dual axle trailer
tenbear
Northern Vermont, USA
I don't use any chemicals, AFAIK, all they do is cover up the odor with a more pleasant odor. If you have no unpleasant odor there is no reason to use chemicals.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
hallock5
Mine is on meds so it seldom has a break down.
2008 Jayco Eagle Superlite 28.5RLS
2002 Ford 4x4 SuperCab 7.3 (Jr International) Diesel
Sad to say, time to sell to a good home.
five'er
Canada
I'm curious as to why you want to know? Do you have a use for it after?
