RV.Net Open Roads Forum: Technology Corner: Dish for HD reception
 > Dish for HD reception
greg4444
Kingwood, TX
Posted: 05/11/12 04:56pm Link  |  Print  |  Notify Moderator
I have Direct TV, and have been using the 18" round dish, but have now installed a HD TV and an HD Satellite reciever. What is the best Sat dish for this? I use a large tripod outside, with hanging water bottle. I hate to get too big of a dish out there in the wind.
Greg and Barbara
2003 Ford F-250 7.3 PSD CC FX4
2002 Fleetwood Pride 30' 5'er
powderman426
ohio
Posted: 05/11/12 05:26pm Link  |  Print  |  Notify Moderator
Aiming is everything. A fellow camper had a tailgater which is quite small and it worked well. I believe it worked well because it has electronics built in that aims it very well. So I surmise the answer lies in how good you are at aiming it.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
Warr Eagle!
Bratt, FL
Posted: 05/11/12 07:05pm Link  |  Print  |  Notify Moderator
You need a slimline 3 or a slimline 5 which are pretty a pretty large dish. If you like to tinker you can use a phase 3 dish with a slimline 3 lnb.
greg4444
Kingwood, TX
Posted: 05/11/12 07:08pm Link  |  Print  |  Notify Moderator
No it's not about aiming, I have a satellite finder, and aiming is no problem. It is about what is the best dish for HD service. You know,on a tripod outdoors, in the wind and all. My little round dish will not get HD.
greg4444
Kingwood, TX
Posted: 05/11/12 07:12pm Link  |  Print  |  Notify Moderator
OK, so slimline 3 or 5... I am only running one TV in the RV. I would like one cable coming from the dish.
rhochnadel
Colorado
Posted: 05/11/12 07:54pm Link  |  Print  |  Notify Moderator
Just remember on the Slimline 3 you will need a power inserter in the line. Then everything runs on one cable. Good Luck!
'05 Keystone Challenger TPK
'01 Chev 2500HD Duramax/Allison
Corgi "Pippin" & cat "Sundance"
AdamBryner2012
Springfield, Illinois
Posted: 05/11/12 07:58pm Link  |  Print  |  Notify Moderator
Get the 5. We use it with the SWIM system for 3 HD TV's in our RV running from one dish, with 1 LNB, and 1 cable.
mikestock
Vestavia Hills, AL, USA
Posted: 05/11/12 09:56pm Link  |  Print  |  Notify Moderator
You only need a power inserter if you go with a SWM (single wire multiswitch) LNB. If you only plan to use one tv and no DVR best go with the legacy (non-SWM) setup. Much less involved.
I would go with a Slimline 3. The 5 is more difficult to properly aim and the extra two satellites only get you the SD locals if you happen to be in a small market area. If you are going HD who cares where the SD locals are anyway? All HD is on the KA (99 and 103) satellites so all you need is the Slimline 3 no matter where you live.
2005 F250 Crew Cab LWB Power Stroke, 2007 Montana 3500RL Fifth Wheel,Honda EU3000IS, Twin Honda EU2000i's, S&W security system
don/lou
Brandon MB Canada
Posted: 05/12/12 07:50am Link  |  Print  |  Notify Moderator
Mikestock has got it right!
Thats what I have been using for past 3 years
see signature
Don
Don & Louise
2000 Coachman Catalina 330 MSB /F53
Rear air bags, 4 Koni FSD Shocks & Davis Front TruTrac
2008 Impala- Remco Lube Pump , Blue OX tow bar & Brake Buddy
Winegard roof dish for Bell Expressview HD tv
SL3 HD- TV4RV tripod set up for Direct HD tv
Warr Eagle!
Bratt, FL
Posted: 05/12/12 07:53am Link  |  Print  |  Notify Moderator
I also agree with mikestock.
