RV.Net Open Roads Forum: Technology Corner: Dish for HD reception
 > Dish for HD reception
greg4444
Kingwood, TX
Posted: 05/12/12 08:22am Link  |  Print  |  Notify Moderator
I ordereded a slimline 3 last night with SWM before I saw the post on the legacy. I have a 5th wheel, and wonder where is the best place to locate the power inserter for the cable? Outside near DSS port, or inside in cabinet? If inside in cabinet, I guess that would put power through the park cable line too. Also, do you need a special signal finder for the slimline?
Greg and Barbara
2003 Ford F-250 7.3 PSD CC FX4
2002 Fleetwood Pride 30' 5'er
Clay L
Sioux Falls, South Dakota
Posted: 05/12/12 08:38am Link  |  Print  |  Notify Moderator
I don't know what tripod you are using but be aware the new HD dishes require a larger support tube/pipe - 2 inch as I recall.
A number of people have recommended this guy HERE as a source for tripods and other accessories for the Slimline dishes.
I went with the Winegard SK3005 automatic dish and am very happy with it. I still carry the old 18 inch dish and tripod so I can have TV if trees get in the way. That will be SD only but historically I have only needed it once a year or so. I can live with SD for a night or two.
Clay (WA5NMR), Lee (Wife), Katie (cat).
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
don/lou
Brandon MB Canada
Posted: 05/12/12 08:41am Link  |  Print  |  Notify Moderator
You do need a special meter with SWiM!!
You don't with legacy (non-SWM) setup. Much less involved.
If it were me I would change my order??
FWIW
Don
Don & Louise
2000 Coachman Catalina 330 MSB /F53
Rear air bags, 4 Koni FSD Shocks & Davis Front TruTrac
2008 Impala- Remco Lube Pump , Blue OX tow bar & Brake Buddy
Winegard roof dish for Bell Expressview HD tv
SL3 HD- TV4RV tripod set up for Direct HD tv
Lantley
Ellicott City, Maryland
Posted: 05/12/12 09:20am Link  |  Print  |  Notify Moderator
I have no dog in this fight but adding HD to the Direct TV systems seem to have gotten quite involved. Not as simple (or cheap lol) as just aiming a 18" dish.
07'Duramax dually,12'Open Range 399BHS
Hawkshead TPMS,Hensley BD3,Killerbee exhaust brake
Blue Ox Bedsaver,air bags w/compressor
Arvika pin box bike rack,Bak Flip tonneau cover
5500 Onan LP,EMS-HW-50
14'Porta Bote w/8.0 Nissan
Vu Cube 2000,Splendide 2000S
greg4444
Kingwood, TX
Posted: 05/12/12 09:21am Link  |  Print  |  Notify Moderator
Yes, I am going to try and change my order. That way I won't need $100 special signal finder, or $25 power inserter!
greg4444
Kingwood, TX
Posted: 05/12/12 09:29am Link  |  Print  |  Notify Moderator
I hear you Lantley, I think I am about ready to throw in the towel on HD, just stick with non HD, little 18" sat dish, little tripod, everything is easy and works fine. Anybody want to buy my brand new DIRECTV H25 High Definition MPEG-4 HD Set Top TV Receiver H25NC-500 NIB... for $100? I payed $150 for it last week.
mikestock
Vestavia Hills, AL, USA
Posted: 05/12/12 10:07am Link  |  Print  |  Notify Moderator
If you have an H25 receiver I believe the SWM system is required and the 18" dish is no option. I would look for a way to run a dedicated RG6 coax out from your receiver. I drilled and ran permanent cable with barrel connector out through the bottom of the slide where my entertainment center is located. This is cleaner and simpler than getting involved with the cable input, antenna amps, etc. The power inserter is located right near the receiver. I would even try it without the PI if you only have one receiver. I've seen it work.
You can't use a regular signal strength meter with SWM unless you use it with a ASL-1 adapter (about $30). If you use a meter the PI cannot be connected to the receiver during the search. All you need to do is preset the tilt/skew on the dish and forget about it. Search for the 101 satellite just like with the 18" dish. The HD, 99 and 103 satellites will be there.
The alternative is, of course, to set everything up and watch or have someone watch the tv screen.
You know you won't be happy until you get this worked out.
2005 F250 Crew Cab LWB Power Stroke, 2007 Montana 3500RL Fifth Wheel,Honda EU3000IS, Twin Honda EU2000i's, S&W security system
powderman426
ohio
Posted: 05/12/12 10:33am Link  |  Print  |  Notify Moderator
$100 meters, tripods, switches, messing around aiming. Not me.
After I saw how easy it was to setup the Tailgater, there is no way I would mess with all that crap.
The procedure went like this.
Plug cable into tailgater, and drop it on the ground aimed somewhere towards the southwest, plug cable into trailer, turn on tv, watch tv.
It doesn't get any easier than that.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
Clay L
Posted: 05/12/12 11:12am Link  |  Print  |  Notify Moderator
You can't get Direct HD with the Tailgater so it won't work for the OP but it seems to be great for Dish Network.
mikestock
Posted: 05/12/12 01:19pm Link  |  Print  |  Notify Moderator
OK, if you're happy with SD. I still have an old collection of 33 RPM records but I don't care to go back and listen to that scratchy sound very often.
Read the title of this thread.
