RV.Net Open Roads Forum: Class A Motorhomes: HELP! EMERGENCY! NEED HELP NOW!
 > HELP! EMERGENCY! NEED HELP NOW!
Page of 6
MSHappyCampers
Columbus, MS
Posted: 05/12/12 09:38am Link  |  Print  |  Notify Moderator
Got up this morning getting ready to leave the campground and the two front slides won't go in! I've checked everything I know but still no luck. My first thought was that one of the outside storage doors was not closed, but checked all of them. I can't find a fuse or breaker that says it is for the slides, but I checked ALL of them with a meter. Any ideas on this?
Joe & Annette
2002 Monaco Windsor 40PBT
MountainAir05
New Mexico
Posted: 05/12/12 09:42am Link  |  Print  |  Notify Moderator
Is it electracal or hyd? Do you hear a noise at all?
tohare
CNY and Florida treasure coast
Posted: 05/12/12 09:43am Link  |  Print  |  Notify Moderator
first question, do they have power? You should have a crank to manually slide them if it is a power issue. Or is something jammed..? Did you open compartments and look up? Also, something jammed inside??
hohenwald48
Hohenwald, TN
Without any info on rig type can only guess. E-brake set, compartment doors closed, check door switches for wires pulled off, fuses, jacks up or down as required, air pressure up, engine on or off. Many manufacturer variables and interlocks.
2008 Fleetwood Jamboree 25G
1999 Jeep Wrangler
100% Solar Powered Home
When seconds count, the police are only minutes away.
lj2654
weeki wachee, florida
Posted: 05/12/12 09:52am Link  |  Print  |  Notify Moderator
Be sure you are in neutral.......pb set!
2001 Beaver Contessa Naples 40
2005 Honda CRV Toad
retired AirForce
harold1946
Surprise Arizona
Posted: 05/12/12 09:54am Link  |  Print  |  Notify Moderator
Another wild guess. Is the drivers seat all the way forward? Ours is not a Monaco but the front slide has a safety lockout that will not allow the front slide to retract without the drivers seat in the full forward position.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer toad
lj2654
Posted: 05/12/12 09:55am Link  |  Print  |  Notify Moderator
hyd fluid low.......
The Texan
Cascade or Meridian, Idaho
Posted: 05/12/12 09:56am Link  |  Print  |  Notify Moderator
The slide relays are in the rear battery compartment. Will say slide right on them. Unplug each and then re-seat it. Make sure your generator is running, or you are plugged into 50a shore power, so there is plenty of juice and that the ignition key is turned off. If nothing works, each slide can be manually cranked in with a box wrench or a ratchet, but it is a chore.
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
'05 HR Endeavor 40PRQ, 400 Cummins-Pulling our '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2010 Rzr or 01 V Star in back.
Where the wheels are stopped today
Noel
Southern Oregon
Sometimes when a circuit breaker pops, it does not move all the way to the other side. It can appear to be OK. Check each breaker for movement and if you find it, move it over and back to reset.
No crank? GSERA will send you a mobile mechanic to help.
Noel
2003 National Dolphin LX 6335, W22, 8.1L
MSHappyCampers
Columbus, MS
Posted: 05/12/12 09:58am Link  |  Print  |  Notify Moderator
Can't hear any sound when pressing the switch to retract the slides. Since both the front slides are not working, I would think it's a power issue, but as I said, I have checked everything I can find. I made sure the air pressure was all the way up, checked the connections on the bay door switches, etc.
Page of 6
