RV.Net Open Roads Forum: Class A Motorhomes: HELP! EMERGENCY! NEED HELP NOW!
 > HELP! EMERGENCY! NEED HELP NOW!
Page of 6
lj2654
weeki wachee, florida
Posted: 05/12/12 09:58am Link  |  Print  |  Notify Moderator
I am assuming that all of the other slideouts on your motorhome are working properly. Your problem could be something as simple as a bad switch for that particular slideout, or it could be a bad slideout control box (the electronic brain).
2001 Beaver Contessa Naples 40
2005 Honda CRV Toad
retired AirForce
lj2654
Posted: 05/12/12 09:59am Link  |  Print  |  Notify Moderator
parrish200
Twin city Ga
Posted: 05/12/12 10:03am Link  |  Print  |  Notify Moderator
I am new to Rv's But had it happen several times on my Sunny Brook and everytime is was the converter. Should be a master reset. I think hold 10 seconds. Hope it Helps
MSHappyCampers
Columbus, MS
Posted: 05/12/12 10:15am Link  |  Print  |  Notify Moderator
Found the slide-out control board in the rear electrical compartment. Unplugged and replugged the three relays. Checked the two fuses on the board. checked the 12VDC to the board. Moved the driver's seat all the way forward. Still nothing!
Joe & Annette
2002 Monaco Windsor 40PBT
MSHappyCampers
Columbus, MS
Posted: 05/12/12 10:18am Link  |  Print  |  Notify Moderator
The rear bedroom slide works, the two front slides do not. Since two of the three do not work, it's unlikely that two switches would go bad at the same time.
ArchHoagland
Clovis, CA, USA
Posted: 05/12/12 10:21am Link  |  Print  |  Notify Moderator
My slides won't move if the ignition key is turned on.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Nothing is either good or bad, but thinking makes it so.
Mr.Mark
California/Tennessee
Posted: 05/12/12 10:50am Link  |  Print  |  Notify Moderator
MSHappyCampers.... I had this happen and finally got it fixed. The computer board connectors apparently where not making good contact. So the repair facility put new ends on and it worked.
Are you saying your rear slide is hydraulic too? We have four slides, 3 hydraulic and 1 electric. The slide the bed is on is electric.
Also, on yours, near or at the hydraulic pump you might have two fuses. Our manual said that ours did but I couldn't find them. I called Monaco and they said ours did not (but the manual says we do)... go figure!
An '02 might have those fuses at the pump so check those.
Good luck!
MM.
Mr.Mark
2008 Monaco Dynasty, 42.2 ft., 4 slides, 425 hp clean-air Cummins diesel
2013 Honda CR-V EXL, AWD, w/Nav, SMI Air Force One vacuum-assisted braking
2ndhom
Eugene, Oregon
Posted: 05/12/12 10:51am Link  |  Print  |  Notify Moderator
Try turning the main batt switch off/on ... coach & chassis. Maybe a relay needs to re-set. Are you on or off shore power? You've tried re-setting the breakers? Your ignition is off?
wolfe10
Posted: 05/12/12 10:52am Link  |  Print  |  Notify Moderator
As many posts are suggesting, pull out your coach owners manual and go through each of the slide "inter-locks". Suspect one of them is not "proper".
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
MSHappyCampers
Columbus, MS
Posted: 05/12/12 10:53am Link  |  Print  |  Notify Moderator
Good luck!
MM.
I'm not sure if all three slides are hydraulic. Where is the hydraulic pump you mentioned?
Page of 6
