I just found the problem with the bedroom slide also. If I press hard on the rocker switch in the "Out" position it will not work. I can release just a little pressure off the switch and it works every time. The other side of the switch, the "IN" side, works! fine. I will call Monaco for a new switch and solve that problem!
Again all, thanks a million for coming to my rescue! We will be able to hit the road tommorrow morning!
MSHappyCampers wrote: I will call Monaco for a new switch and solve that problem!
Again all, thanks a million for coming to my rescue! We will be able to hit the road tomorrow morning!
NO NO, don't pay the Monaco price for anything, except as a last choice. First try Northwest RV supply and if they don't have it, then go to the Monacoers forum and check who the supplier for the switch is and go direct.
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever" '05 HR Endeavor 40PRQ, 400 Cummins-Pulling our '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2010 Rzr or 01 V Star in back. Where the wheels are stopped today
Now on our coach 2012 Georgetown, with electric slides, there is NO manual crank, asked when we did our walk through.. bad design on their part.. I was going too suggest reshutting all the bay doors. Glad it all worked out
"2012 Forest River 360 DS"
"Ford V-10"
"2013 Toyota Corolla on Tow Dolly"
I noticed that the OP has a Monaco product too. Our slides will work with the bay doors open. All of our bay doors are side hinged except the water/sewer bay door that opens upward like a bus cargo door (no slide there). Sometimes you just never know what can cause a problem like that.
MM.
Mr.Mark
2008 Monaco Dynasty, 42.2 ft., 4 slides, 425 hp clean-air Cummins diesel
2013 Honda CR-V EXL, AWD, w/Nav, SMI Air Force One vacuum-assisted braking
My friend has a GeorgeTown and he has the switches on his compartments. He too had trouble, and had a tech came over at the camp ground to find the problem. What the tech did was disconnect all the switches as he said they are just trouble. The switches are cheap and not moisture proof. Good Luck...
"No One Cares What You Know, Until They Know That You Care!"......."God Bless America"
2003 Pace Arrow 34W, F-53 V-10 22,000#, Avg 8.2 MPG
ScanGauge II, Voltage Booster, Progressive Industries EMS
Water Softener, Safe-T-Plus, Rear Trac Bar, 4 Koni FSD's
