RV.Net Open Roads Forum: Technology Corner: Cell Phone Antenna Mounted to TV Antenna
 > Cell Phone Antenna Mounted to TV Antenna
hypoxia
Arizona
Posted: 05/12/12 10:31am Link  |  Print  |  Notify Moderator
Anyone have a picture of a cell phone trucker antenna mounted to the RV's TV antenna?
Jim
2003 Fleetwood Revolution 40C
Pirate
Appalachia
Posted: 05/12/12 05:16pm Link  |  Print  |  Notify Moderator
I don't see that happening without one of those tiny ground plane arms hitting into the roof when the antenna is down.
joe b.
Posted: 05/12/12 05:35pm Link  |  Print  |  Notify Moderator
That is the problem I faced so ended up mounting it to an aluminum channel fastened to the roof rack. That with an amplifier attached to the cable inside sure makes a difference for us when out west. I use a Wilson Sleek amp.
joe b.
Stuart Florida
Formerly of Colorado and Alaska
Chevy 3500 DRW Dmax CC - Rockwood 8281 SS 5th Whl & 2008 Lance 845 TC
www.pajbcooper.com web site
Alaska Trip 2011 posted
Colo-Utah-Ariz 2012 trip posted
"Without challenge, adventure is impossible".
bigbubba1959
Illinois
Posted: 05/12/12 09:27pm Link  |  Print  |  Notify Moderator
I dont need to use mine all the time. So i bought 10 ft piece of 2" pipe. Cut in half use a union. Cap off top and drill and install antenna through the pipe and raise it up!! disassemble and stor when not in use.
if once you dont suuuceedd
If once you deont succeed
If once you dont succeed try tryyyy
If once you dont' succedd
Ok if once you dont succeed just freaking DO IT!!!!!!!!!!
Daybreak
Southeastern Indiana
Posted: 05/13/12 04:12pm Link  |  Print  |  Notify Moderator
Go here: Jack Mayer Communication and look at the Antenna Mounting Methods. There are pictures of what you are looking for.
joe b.
Posted: 05/13/12 04:19pm Link  |  Print  |  Notify Moderator
Daybreak, that is an excellent site for ideas. Never thought about using an exterior door handle to raise the radials enough to clear the roof. Will have to try something like that the next time.
mikestock
Vestavia Hills, AL, USA
Posted: 05/13/12 05:12pm Link  |  Print  |  Notify Moderator
I have an old Wilson Trucker that I used until I could no longer adapt it to my newest smart phone. None of them seem to have a connector for the coax. Can the Sleek be hardwired to the Trucker coax? Will this improve my 4G coverage?
2005 F250 Crew Cab LWB Power Stroke, 2007 Montana 3500RL Fifth Wheel,Honda EU3000IS, Twin Honda EU2000i's, S&W security system
MrWizard
Traveling
Posted: 05/13/12 06:28pm Link  |  Print  |  Notify Moderator
I took the easy way out
I mounted a thin steel plate to the inside top of the forward overhead cabinet
then stuck the antenna from the wilson sleek on it
its upside down, but it makes no difference to the antenna, its still vertically oriented
works good and everything is inside
If I want to change antennas to something longer, maybe I will have to mount it outside
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
hypoxia
Arizona
Posted: 05/13/12 08:19pm Link  |  Print  |  Notify Moderator
That is excellent. I did mount it on the TV antenna & don't have any interference issues. It may not be the best for the road but it will be for the forest. Wizard as usual has a good idea in mounting it upside down inside, that may be usefull when travelling if the horizontal mount doesn't work well.
