MKish
SF
My new camper has a small Dometic 3-way fridge. I plugged it in and turned it on to cool and after about 28 hrs, it was at about 50 F. So I threw my perishables in a cooler and ran the fridge on DC for about 3 hrs while I went on a quick test trip. Temp stayed about the same. Reached destination and ran the fridge on propane for about 24 hrs. It still didn't cool enough.
Sooooo, what did I forget? My previous 3 way fridge(from 1974!) would drop to below 20 F in an hour on shore power. I am underwhelmed with this new technology.
Is there something I should try? I did read the manual.
Thanks!
robatthelake
Vancouver Island
That doesn't sound very good! When You say New ,is that Brand New or New to you?
Rob & Jean
98 Dutch Star Diesel Pusher ..92 Tracker 4X2
danoren
Where ever I Camp
Did you adjust the tem. level ?
F-350 ,2006,XLT,SD,LB,EC,6.0LT,Auto,SRW.
5W Cruiser 2006 CF29CK Crossroad
RVing 4-5 months every summer since 2002.
P.A,Good Sam,TomTom GO720
Website
MrWizard
Traveling
check the roof vent for blockage
even on electric, the heat must escape, there must be ventilation from the access door to the roof vent
other wise it sounds like a malfunction and warranty problem
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
BobsYourUncle
Surrey, BC Canada
I hate to ask the obvious, but was your camper level?
I know my old Dometic is very fussy about being level or else it doesn't cool effectively.
Duramax / Allison
Fire Red
95 Sportsmen 25.5' TT
81 Citation 25' "Tail dragger" "Under construction"
"Workin' man's rig"
Bob's Trucks
Check Out My Rebuild Project
Project Feedback
nbking
Ottawa Ontario Canada
I had the same problem with my 3 way frig. Called a Technician who came and adjusted the temperature knob - frig worked fine.
Cost my $40.00 to find out. When all else fails, read the instructions.
dougrainer
Carrolton, Texas
1. NO refer, no matter how old would drop from warm to below 20 degrees in an hour. YOU have a faulty memory or bad tstats.
2. You NEVER operate on DC unless you are driving. DC operation is a Maintaner of previous temp and will not continue a cool down while on DC
3. Is this the first time you have used it? How are you measuring the temp? The only way to measure interior temp accurately is to leave a glass of water in for 24 hours on MAX cold on the tstat and then measure the water temp. Doug
skipnchar
Topeka or somewhere else
Nowhere near enough information about the fridge you purchased to even guess. Since it apparently is not working on either LP or electric mode (12 volt mode is unknown but usually will not actually COOL a fridge anyway) then I would suspect the thermostat is not working correctly. This guess assumes that a whole LOT of other things are working correctly though and that's not a sure thing either. Might test the fuses on the control board for starters.
CA Traveler
The Western States
It could also be a air leak at the door seal or in the back.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
MKish
SF
Thanks for the input. I don't know much about these things. It's a shiny new RM-8501 and I did read the instructions, really! It was level and turned up to the coldest setting.
I'll check the vent and seals and any fuses I can find. I am hoping it's something easy and I can avoid having the thing serviced.
