RV.Net Open Roads Forum: Travel Trailers: Kreg jig
 > Kreg jig
Downwindtracker2
BC
Posted: 05/12/12 11:41pm Link  |  Print  |  Notify Moderator
I guess you oldtimer RVers know this already,Kreg countersink jig is great for trailers. I bought and used one today,it made joining 1x a lot easier than side screwing I had done before.
Adventure before dementia
BobsYourUncle
Surrey, BC Canada
Posted: 05/12/12 11:59pm Link  |  Print  |  Notify Moderator
Duramax / Allison
Fire Red
95 Sportsmen 25.5' TT
81 Citation 25' "Tail dragger" "Under construction"
"Workin' man's rig"
Bob's Trucks
Check Out My Rebuild Project
Project Feedback
gbopp
The Keystone State
Posted: 05/13/12 04:33am Link  |  Print  |  Notify Moderator
Apparently I'm not old enough to know what you're talking about.
Is This the jig?
Bob Landry
Austin, texas
Posted: 05/13/12 06:27am Link  |  Print  |  Notify Moderator
Is This the jig?
That's it. The correct terminlogy is Pocket Hole Jig. I usd one to build cabinets in a Class B and it makes for a really nice job. Cabinet makers have been using them for a long time. If you do very much construction type stuff, they are well worth the price.
2011 Tundra 5.7L
2011 Keystone Outback 277RL
Bajahaha
Kalifornia
Posted: 05/13/12 06:31am Link  |  Print  |  Notify Moderator
It is a wood working device to join two boards at angles,generally 90 degrees.
Relatively new, has been advertised extensively on various DYI TV programs
NO I do not own one!
sdm
Roadpilot
NH Seacoast
Posted: 05/13/12 06:35am Link  |  Print  |  Notify Moderator
I own one and it'sa great. You can make faceframes for cabinets a lot faster with them.
2006 Millennium Prevost
2013 Chevy Avalanche LTZ Black Diamond
2009 HD Electra Glide CVO Screaming Eagle - mine
2009 Yamaha VStar950 - DW
Cruiser Caddie motorcycle lift
Tom_M
New Hope, MN
Posted: 05/13/12 07:22am Link  |  Print  |  Notify Moderator
Harbor Freight has a pocket hole jig kit that looks more robust than the Kreg and is cheaper:
Harbor Freight jig
Tom
2005 Born Free 24RB
LAdams
Northern Illinois
Posted: 05/13/12 08:17am Link  |  Print  |  Notify Moderator
I own one and have used it several times for the trailer, and other projects as well... A fine tool that does a great job!!!
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
Sold Trailer - not RV'ing at this point in time
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
Downwindtracker2
BC
Posted: 05/13/12 10:59am Link  |  Print  |  Notify Moderator
I used it for installing backing 1x4s on the flat, face to face. The factories use staple across the joint.
ktmrfs
Portland, Oregon
Posted: 05/13/12 11:21am Link  |  Print  |  Notify Moderator
yup, works great. BTW my trailer cabinetry uses pocket holes on all the face frames etc. rather than staples. much more robust and easier to disasemble/modify if needed!!
2011 Keystone Outback 295RE
2004.5 Silverado 4x4 CC/SB Duramax/Allison
 > Kreg jig
