RV.Net Open Roads Forum: Fifth-Wheels: Water heater stink
 > Water heater stink
buc1980
houston tx
Posted: 05/13/12 07:01am Link  |  Print  |  Notify Moderator
The water in my heater stink when I clean it I see chunk of calcium and gelly come out.What I can do to prevent that build up.The rod was in fair condition.Anybody have that problem?Any idea?
2011 Ford F350 DRW,2005 Kountry Star 35ft,Breaksmart controller(not install I use Ford controler ),Equa-Flex.6 points LIPPERD Level-up.
Jim Cindy
Northcentral, PA
Posted: 05/13/12 08:18am Link  |  Print  |  Notify Moderator
You likely are going to need a decent filter and a portable water softener. Texas and other points southwest have some very hard water with tons of minerals in it. We use the one shown below when in the valley.
water softener
PBH Portable Beach House
2008 GMC 2500HD Duramax Allison
2009 Cameo 34CK3
MorRyde IS, Disc Brakes, G614's
PullRite Super Glide Hitch
Propane fueled Yamaha EF 2400is
buc1980
houston tx
Posted: 05/13/12 04:38pm Link  |  Print  |  Notify Moderator
Thank you all for the info.This weekend I drain the water heater and I wash it inside.The smell is gone now.
skipnchar
Topeka or somewhere else
Posted: 05/13/12 08:28am Link  |  Print  |  Notify Moderator
If the odor you mention is that of sulfur then you probably have some sulfated water from some source. the cure is to completely sanitize your water system then flush with plenty of potable water then perhaps give it a vinegar or baking soda treatment (similar to what you do with a coffee pot). filters or softeners will do little to help with sulfated water.
Good luck / Skip
n7bsn
Yes
Posted: 05/13/12 08:56am Link  |  Print  |  Notify Moderator
So far the advise has been good, in addition to the possibility of sulfur in the water, it is possible to get anaerobic bacteria in the water-heater. When a water-heater has been left sitting for some time, the regular bacteria use up all the oxygen, and the the anaerobic take over and go to town.
The deposits are just because you have been using really hard water.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
