RV.Net Open Roads Forum: Travel Trailers: Water softener- will pellets work?
 > Water softener- will pellets work?
relliott75
Kansas
Posted: 05/13/12 11:54am Link  |  Print  |  Notify Moderator
I told DW to get calgon water softener to try the geo method for the black tank and she came home with a 40 pound bag of rock salt. Heck, should work the same while adding a bit of scouring ability while it dissolves in the water, right? The thought was to add two cups of salt, 40 pounds of ice and 5 gallons of water to try and get the tank cleaned up (primarily so the sensors will work). Anything wrong with this train of thought? We'll be driving about 1000 miles.
Thanks in advance,
Rob
2007 Jayco 29FBS / GVWR 8800
2010 Dodge Ram 2500 6.7 CTD MEGACab 4x4 Laramie
Kansas City, Kansas
DW, 2 Kids & 100 pound GSD!
naturist
Lynchburg, VA
Posted: 05/13/12 11:56am Link  |  Print  |  Notify Moderator
NO.
All that will do is turn your discharge into brine. It will do nothing for the geo method, and it won't help clean/flush the crud out of your black tank.
Rock salt is what you would use to regenerate a water softener, but it does absolutely nothing helpful in this use. Calgon Water softener, or 20 Mule Team Borax contain NO rock salt. Either of those would work wonders. Rock salt is a total waste.
2oldman
Winchester WA
Posted: 05/13/12 11:57am Link  |  Print  |  Notify Moderator
naturist wrote:
NO.
x2.
What works every time is forgetting about cleaning it up and looking down the toilet to see when to dump.
* This post was edited 05/13/12 12:04pm by 2oldman *
greende
Syracuse,NY
Posted: 05/13/12 12:34pm Link  |  Print  |  Notify Moderator
2oldman wrote:
naturist wrote:
NO.
x2.
X3
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
relliott75
Kansas
Posted: 05/13/12 01:02pm Link  |  Print  |  Notify Moderator
Damnit......back on another store run.
CincyGus
Cincinnati
Posted: 05/13/12 04:44pm Link  |  Print  |  Notify Moderator
I'd be worried about what the salt water would do to the tank level sensors also. Bad idea IMO.
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
Ole Man Dan
Gadsden, Alabama
Posted: 05/15/12 01:56pm Link  |  Print  |  Notify Moderator
One cup of Calgon liquid, and a cup of Dawn Dish detergent,
then add 5-6 gal. water and let it slosh on the way to and from camp. Works for me.
After the second treatment, my sensors were clean and I once again have accurate readings.
The ole look down the hole still works, but there are things I had rather do...
