HUNTERJEFF
ORANGE COUNTY NY
I am thinking about using eternabond tape on all my vents. No leaks yet but don't want any. What do you guys think of this product?
gbopp
The Keystone State
It's a fantastic product. Use it on all your seams and edges.
Sailbad
Bernardo, New Mexico or Quartzsite
Properly applied..... It's the greatest thing since sliced bread.
Dave C.
2005 Silverado 2500 CC
Duramax 6.6 3.73 V-2
2003 Wildcat 27RL
B&W with Companion
Prodigy
Keep Your Powder Dry....This Ain't Gonna Be Fun
JumboJet
Tontitown Arkansas
Sailbad wrote: Properly applied..... It's the greatest thing since sliced bread. ...and hope YOU don't ever have to remove whatever is being sealed by it.
Pete_k
Stantonville Tn
Good luck with it, But don't think I will be using it also. Not sure it would be easy to get back off if you were ever to need to replace anything also.
Pete
2004 Duramax/allison Trans C/C 4x4
2012 Landmark Key Largo
2008 Lund 1825 Pro Guide Tiller, With a Evinrude 90 HP E-Tec
Live near Pickwick Dam and the Tn river
Home Skillet
Pearland Texas
It's easy to remove whatever you seal with Eternabond.
Just take a razor blade and cut the tape.
Eternabond just works too well to fool with anything else.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,SmarTire,Bilstein Shocks,Trans temp guage,Lowrace iWAY
Photomike
Southern Alberta or where the camper is parked!
I had a vent that was done with MANY layers and had to remove it as the leak was in the vent not at the seal. Thought that I was in big trouble looking at the mess that was there but I used a chisel to peal it back and to get at the screws. A sharp knife around the edge of the vent to get the vent off, then used a sharp chisel to clean up the rest on the camper and it went very fast.
Would use it again as the other vents that have it have never leaked.
2002 GMC 2500HD 4x4 4 Door
1992 Northern Lite 9'- 6" Camper
Homemade Cargo Trailer for hauling supplies
Advanced Elements Kayaks
Border Collie Guard Dog
Klueck
x2
recycler
michigan
great stuff seen it on commercial roofing...plan to use double sided on all my windows and vents
JIMNLIN
out here
trailernovice
IMO Eternabond isn't the best choice for that type of job. If you have a new unit I would contact the dealer or manufacture for their input as other have found out the hard way its not the best idea as one RV.net member found out:
Mission TX
Posted: 11/29/11 11:13am Link | Quote | Print | Notify Moderator
A while back, I opened a thread asking whether eterna-bonding the roof seams on an almost-new TT as a preventative measure was a good idea ...the virtually unanimous opinion was 'yes'....
Well, took the TT to the selling dealer today for some minor work...rep. sees the tape job, asks 'why on earth did you DO that'?, and tells me that: a.) it's not necessary b.) it'll trap water if any water ever gets beneath the tape, and c.) any claim under the roof warranty may get kicked on grounds that the roof has been 'modified'....
thought i did the right thing by sealing the seams, but now not so sure....
trailernovice
Mission TX
'97 Park Avanue 28' 5er 11200 gvwr two slides
