RV.Net Open Roads Forum: Toy Haulers: Water system / holding tank maintenance
Search only in Toy Haulers
 > Water system / holding tank maintenance
d-mac1
Colorado
Posted: 05/14/12 08:50am Link  |  Print  |  Notify Moderator
I've read about how to sanitize the water tanks and lines after winter storage. Basically, the best method I've read about involves dumping bleach into the water supply hose, connecting it to trailer, and filling up the water supply tank and then pumping it through all lines and faucets and flushing it out twice.
I'm receptive to enhancements to this approach but really my question is what should be done during the season when a trailer is used only periodically?
If I use the trailer every couple months, should I run in some bleach after each trip to assure that things don't start growing in the lines and then flush it out before each succeeding trip?
What about the holding tanks? Naturally I'd empty and flush upon my return, but is there something good to leave in them to keep em fresh?
Thanks.
2009 Ram 2500 CTD
2012 XLR 300X10
2006 KTM 450 EXC
Dave Wilburn
Ogden UT
Posted: 05/14/12 09:12am Link  |  Print  |  Notify Moderator
Pesonally, I sanitize when dewinterizing, then I just drain it and open the low point drains if it won't be used for more than a couple months during the season. If there is little to no water in the tank or lines, it limits what can grow in it.
Sanitizing once a year is probably overkill anyway....When was the last time anyone sanitized the pipes in their house?
04.5 Ram 3500, '12 Voltage 3905 Epic, 69 baja bug
nayther
Burbank, CA
Posted: 05/14/12 09:44am Link  |  Print  |  Notify Moderator
I just keep the fresh water tank full all the time, without air bad stuff can't grow. We use our trailer at least once a month and never winterize in So Cal.
DIRT BIKES RULE
'12 Duramax CC short bed
'06 3005 Rage'n Falcon
Eycom
32043
Posted: 05/14/12 11:52am Link  |  Print  |  Notify Moderator
As a full timer, I tap into the CG's hose bib, but use the on-board F/W tank often during transit. The chlorine in city water is good for about a month and should be recycled within that period of time. I also use a faucet filter for added filtering and consistent taste in drinking water. I sanitize about four times a year to be on the safe side. After all, it's still just a holding tank. Two months between trips? To be safe, I'd sanitize if planning to use the tank for drinking water.
Might want to put a little more thought into that before drinking from the RV F/W holding tank.
I don't use chemicals in the gray or black tanks, just water. And I never let the black tank dry out. There's always a few gallons replaced after emptying. Wouldn't be a serious problem if it froze and I don't need to start a pyramid.
RVn Full-time
BobWanderer
Perris,Calif,USA
Posted: 05/14/12 12:35pm Link  |  Print  |  Notify Moderator
Same here, thats My "earthquake" water supply, along with a few cases of bottled water.
2008 GMC 2500HD 4X4 DMax CC LB
2004 Thor Wanderer Wagon 247WTB
2006 TE450 Husky
2007 Rhino Sport Edition
Y-Guy
Tri-Cities, WA
Posted: 05/14/12 02:05pm Link  |  Print  |  Notify Moderator
Might be overkill but since I also fill on the road at some campground I still sanitize once a year with the host/bleach method. I don't sanitize in between trips, however I have a few times after I filled at campgrounds that I didn't totally trust the water supply.
Our RV: '07 Winnebago Sightseer 35J
Our Toys: Four Winns Horizon 190, Polaris Sportsman 500's & Honda Recon's
BobWanderer
Perris,Calif,USA
Posted: 05/14/12 06:10pm Link  |  Print  |  Notify Moderator
If I fill on the road somewhere, I dump the tanks when I get home and re-fill with known quality water and figure the Chlorine will take care of things ??
d-mac1
Colorado
Posted: 05/14/12 07:16pm Link  |  Print  |  Notify Moderator
Thanks for the replies guys! Our home water supply is well water and no chlorine so I won't get any chlorinization upon fill-up unless it is in the water I get somewhere along the way.
kford131
Colorado Springs, CO
Posted: 05/14/12 10:16pm Link  |  Print  |  Notify Moderator
I also have well water so generally I bleach the fresh tank in the spring. It actually works out pretty good to bleach the tank and then use that to purge the antifreeze from the lines. The bleach even helps clean out the color from the antifreeze from the tub and crapper. I usually don't fill up with anything but the well water at the house (kids don't like city water).
d-mac1
Colorado
Posted: 05/16/12 08:19am Link  |  Print  |  Notify Moderator
Ok....lots of info on fresh water tanks and lines. I have a plan for that now. I like the idea of leaving full so no air.
What about the black water tank while your trailer sits? Do you guys do anything to keep it somewhat fresh after dumping it and while waiting for next trip?
Thanks.
