kodiakcanuck
Ottawa, Canada
I would like to hang a couple metal signs or pictures in our TT and I read before some have used a 3M double sided tape with good results.
Can someone clarify what type of 3M tape you used? I want to ensure the metals signs stay, they would make quite the dent in the floor if they fell during travel.
Thanks!
2011 Kodiak 240KSSL
Husky Center Line WDH
2010 Dodge RAM 1500 4x4, 3:55, 5.7L - at last, a HEMI
2007 Kodiak 214 HTT (prior)
Dick_B
Palos Heights, IL USA
Search this Forum for `command strips' which seems to be highly recommended.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
JoyceandSteve
Houston, Texas
I use command strips and has worked out very well. Just make sure that you use some alcohol and clean the area where the command strip is going to be used. Otherwise it may not stick. (don't ask how I know this)
Steve & Joyce
2011 Chevrolet 2500 Z71 4X4
2013 Montana High Country 343 RL
1996 Celebrity 200 Boat
2000 Yamaha 1200 LTD Waverunner
2012 Ford Mustang GT (Mama's ride)
Vítejte na víkend doma a Steve Joyce
docj
Fulltime--Home is where we park it
If you are hanging heavier things you should take a look at these: Dual Lock They are part of the 3M Dual Lock product line which is the "big brother" to Command Strips. Although they are hard to find in retail stores I find they are worth ordering because they have much greater holding capability.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2009 Chevy Malibu LTZ with ReadyBrute tow bar/braking system
Official WiFiRanger Ambassador WFRAMB303
Follow our adventures on Facebook at Weiss Travels
thebutler4
Boerne, Texas
I use Velcro on everything I hang up ... that way they can be removed, cleaned and replaced ... If its going to be a heavy item I would use the industrial version. as stated above .. make sure you wipe the area with Alcohol .. that why it holds good.
2012 Dodge Ram 3500 Dual 6.7L High output diesel
2008 Jayco Designer 34RLQS
2013 Harley Davidson Ultra Classic
Full time and loving it
Cancer free since 1/2012
Men, Please check your self for Testicular cancer and Teach your young men how to check as well!
jwangelin
Western New York
I would go to the local hardware store and find either monkey or gorilla hooks. They leave a tiny hole and hold lots of weight. The 2 sided tape would work great at preventing the signs from swinging around.
Good luck
afob3
Maryville, TN
Only downside to the command strips is if you apply to a wallpapered surface. I hung a light toothbush holder in the bathroom of our former HTT. We wanted to move it to the new one. The strips released cleanly as they should but we found giant air bubles in the paper where the weight had pulled it loose. The command strips held great but the glue behind the paper was the weak link.
Lesson learned.. In the new TT I used command strips and hung it on the wooden side of the medicine cabinet.
2012 Koala 25DS
2011 F150 Ecoboost SuperCrew with Max Tow Package
www.familyobrien.net
wbrown62
I've used the Command strips that work like velcro. I have some pretty large picture frames hung using it and have never had trouble. Items can be removed and stuck back on since it is velcro like.
2011 Keystone Bullet 246RBS
2000 Chevrolet Silverado
CincyGus
Cincinnati
wbrown62 wrote: I've used the Command strips that work like velcro. I have some pretty large picture frames hung using it and have never had trouble. Items can be removed and stuck back on since it is velcro like.
X2
I used the command strips with the yellow velcro also. I have a standard home 8"x10" Wood picture frame that has some weight to it hung with these on one of the side walls. velcro in all four corners. It presses in very nicely and is tight and secure. I double check to make sure it's pressed in very well prior to each trip and have yet to have it come loose or be loosened up from traveling down the road. FOr things hung on interior walls (non-outside walls) I use the plastic wall anchors or elf tapping screws.
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
krev
Victoria, BC, Canada
thebutler4 wrote: I use Velcro on everything I hang up ... that way they can be removed, cleaned and replaced ... If its going to be a heavy item I would use the industrial version. as stated above .. make sure you wipe the area with Alcohol .. that why it holds good.
X2
1 husband 2 grown kids
2010 F-350 Lariat King Ranch, CC, diesel, short box
2009 Arctic Fox 27T
