RV.Net Open Roads Forum: General RVing Issues: slide outs
 > slide outs
machunt
cincinnati ohio
Posted: 05/14/12 01:47pm Link  |  Print  |  Notify Moderator
What is everyone using to lube the slides on there units?
tomman
out and about....
Posted: 05/14/12 01:50pm Link  |  Print  |  Notify Moderator
My owners manual says not to lube anything on the slide out mechanism.
TxTiger
North Texas
Posted: 05/14/12 01:57pm Link  |  Print  |  Notify Moderator
Grease and oils attract dirt, I would use something like DuPont Dry Wax Silicone. I use it on my motorcycle chain and everything else I need to lubricate where dirt is an issue.
2000 F250, 7.3 PSD, 6 speed manual, CC, SB
KZ 27TH Toy Hauler, 5,700 lb dry weight/8,000 lb GVW.
2010 Triumph Tiger 1050
2012 Triumph America
2009 Suzuki DRZ 400sm
powderman426
ohio
Posted: 05/14/12 02:02pm Link  |  Print  |  Notify Moderator
My trailer is 16 years old. No lube and still moving fine. So I guess its not necessary.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
korbe
Northern California
Same here.
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
machunt
cincinnati ohio
Posted: 05/14/12 02:32pm Link  |  Print  |  Notify Moderator
ok then that answers my question
fordsooperdooty
Posted: 05/14/12 03:07pm Link  |  Print  |  Notify Moderator
All the above is right on the money!
I'll add that the slideout manufacturers such as Lippert say that they're run during destructive testing up tp 10,000 in/out cycles without lube related failures.
Unless it becomes balky or noisy, in which case use a dry spray lube such as RemOil Dry Teflon or Slip Plate Dry Graphite sprays.
And you can use water to clean them if they get a build up of gunk or road debris. The #1 cause of slideout failure is electrical issues including bad switches or poor electrical contacts.
sirdrakejr
Las Vegas, Nevada
Posted: 05/14/12 03:15pm Link  |  Print  |  Notify Moderator
Moved from 5th wheels to Gen'l RVing Issues.
Frank
John&Joey
Some Location
Posted: 05/15/12 05:24am Link  |  Print  |  Notify Moderator
I'm guessing that most that never use anything don't camp in a high salt air environment.
Valkyriebush
Yuma/Port Townsend
Posted: 05/15/12 07:59am Link  |  Print  |  Notify Moderator
nothing.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
 > slide outs
