RV.Net Open Roads Forum: Towing: Do I really need a WDH
Search only in Towing
Open Roads Forum  >  Towing
 > Do I really need a WDH
moto922
Augusta, GA.
Posted: 05/14/12 01:50pm Link  |  Print  |  Notify Moderator
Just got a 2006 Gulfstream Ameri-lite 21MB TT. Hitch Weight 340 lbs, Drys Weight 3215 lbs. My towing truck is a 1998 Chevy CK 2500 that is low miles and in G/C. When I hitch the TT onto my truck the height of the truck front is the same as it not hitched. The rear height of the truck is 1" less when TT is hitched. I have pulled the TT a few times without WDH and it tows good. I got a drop down hitch shank that tows TT level. My question is, do I really need a WDH.
Thanks,
fla-gypsy
North Florida
Posted: 05/14/12 01:56pm Link  |  Print  |  Notify Moderator
As long as you do not exceed the the ratings tag on the receiver itself you are OK. You need to actually weigh the rig to know for sure though as dry weight means nothing.
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
kaydeejay
SE Michigan, USA
Posted: 05/14/12 01:57pm Link  |  Print  |  Notify Moderator
Agree with Fla-Gypsy. DO NOT use dry weights. What is the trailer tongue weight when loaded for travel?
Then, what is the dead weight rating of your receiver - most are 500#.
That is often doubled with WDH.
Keith J.
Sold the fiver and looking for a DP, but not in any hurry right now.
moto922
Augusta, GA.
Posted: 05/14/12 02:15pm Link  |  Print  |  Notify Moderator
Thanks, I will look at receiver rating when I get home.
Jerry
ScottG
Bothell Wa.
Posted: 05/14/12 03:12pm Link  |  Print  |  Notify Moderator
No, that's just not enough weight and your truck is easily able to handle it without a WDH. Try it and I bet it has no handling effect at all on the truck.
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
kaydeejay
SE Michigan, USA
Posted: 05/14/12 06:48pm Link  |  Print  |  Notify Moderator
How can you say that when:-
- We don't know the LOADED tongue weight of the trailer?
- We don't know the dead weight capacity of his hitch?
[emoticon][emoticon][emoticon][emoticon][emoticon][emoticon]
kwlincoln
North of Houston, TX
Posted: 05/14/12 07:56pm Link  |  Print  |  Notify Moderator
He's no where close to needing a WDH. What's the point of weighing when he is that far in the black?
dodge guy
Bartlett IL
Posted: 05/14/12 09:08pm Link  |  Print  |  Notify Moderator
I agree that I don`t think he needs a WD hitch. an Amerilite is an extremely lite trailer, I`m betting it has a GVWR of 4500lbs at most. 500 pounds TW on a 4500lb TT would be 11.5%. a little low, but a 2500 truck should be able to control a short, lite weight TT. and a hitch change would solve the weight carrying TW issue.
Wife Kim
Son Brandon 16yrs
Daughter Marissa 15yrs
Dog Bailey
07 Cherokee 32B Dexter EZ Flex
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese DualCam Prodigy brake controller
A bad day of camping is
kaydeejay
SE Michigan, USA
Posted: 05/14/12 09:17pm Link  |  Print  |  Notify Moderator
He MAY only be 160# under the hitch capacity without WDH.
I didn't say it was OK, I didn't say it wasn't OK, all I said was without the ACTUAL loaded and spec numbers we don't know.
[emoticon]
blt2ski
Kirkland, Wa
Posted: 05/14/12 09:19pm Link  |  Print  |  Notify Moderator
I used to pull a 12K dead wt trailer with my 96 SW K3500. Granted I did NOT have the stock GM hitch, but an aftermarket that was good to the trailer wt......I pulled all of about 300 lbs off the FA with the stock 6400 lbs rear springs, changed out to 8400 lb springs, and the loss to the FA went down to 200.
With my 6500 lbs TT and 650-700 on the hitch, it was closer to 60 or 80 lbs off the fa, I did notice a difference to a degree with vs without a WD, and a dual cam. BUT, handling in even 50mph cross winds was the same. What I did notice in these upper cross winds, was the trailer moved sideways less with the WD than with out, and less yet with the dual cam.
Marty
Check RV.Net Blogs at: blog.rv.net
