RV.Net Open Roads Forum: Tow Vehicles: Fix & Keep or Trade for New
Search only in Tow Vehicles
 > Fix & Keep or Trade for New
Bearhawk
Away up north
Posted: 05/14/12 03:01pm Link  |  Print  |  Notify Moderator
Okay, here is a question of reliability and faith in a vehicle. Out of curiosity I wonder how many here would keep the faith with a vehicle and how many would dump and run. Like all things it boils down to personal opinions, but seeing as I am not camping these days, might as well play on the computer.
On May 4th my 08 F350 had a message of "Stop Safely Now" pop up, as I got the vehicle to the roadside it stalled out. With the help of a dealer I was able to limp to my destination by a process of wait 60mins, clear codes, re-start. Drive for 45 to 60 minutes and repeat.
On Sunday the 45 mins shrunk to 25 mins and eventually gave up at a dealer and left the truck, and fetched another to get myself, camper, and canoe home. That dealer was not able to get it to perform on road test and deciphered the following codes:
P242D Exhaust Gas Temperature Sensor Circuit High Bank 1 Sensor 3
P242B Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 1 Sensor 3
P2002 Diesel Particulate Filter Efficiency Below Threshold Bank 1
Only the P2002 code existed after the work was done, but they reprogrammed the PCM.
After picking it up 20 mins later it died. Dropped off at yet another dealer, but they cannot work on it until June, so it is getting towed back to the original dealer to get looked at.
Still under Powertrain and emissions warranty for about another year.
So would you still trust your truck after it left you stranded?
Bearhawk (n): A Plansbuilt Amature Aircraft. An expensive hobby that was replaced by 2007 29FBS Jayco Jayflight G2 & 2008 F350 Crew with 6.4L Diesel
At least this adventure flew off the drawing board and running out of fuel is not as dangerous!
ScottG
Bothell Wa.
Posted: 05/14/12 03:08pm Link  |  Print  |  Notify Moderator
Depends on what they find. It may be as simple as rodents getting to wires or the need for a service bulletin. It would also depend on whether they (and you) are certain they fixed it. I certainly wouldn't trade it in just because it broke down once.
I've learned not to talk myself into purchases like that - it just isn't smart in the long run IMHO. However, if it continued to have the same kind of issue pop up then I would seriously start considering trading it in.
Scott, Grace and Wesly
H0NDA eu2000i
45Ricochet
North Idaho
Posted: 05/14/12 03:09pm Link  |  Print  |  Notify Moderator
Under warranty and they can't get to it till June????
My wheel would be squeeking really loud. What's up with the Ford warranties lately. They sure did take care of warranty issues back in 2004-2007.
I'd keep it unless it becomes a habit.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
fla-gypsy
North Florida
Posted: 05/14/12 03:14pm Link  |  Print  |  Notify Moderator
Thats a tough call. Once it is repaired I think (maybe) I would give it another chance. How much faith do you have in the dealers diesel technician? That may be a concern. They are complicated pieces of machinery.
NewsW
US
Posted: 05/14/12 03:16pm Link  |  Print  |  Notify Moderator
Did you mod the vehicle?
Use a tuner?
Run unapproved additives? Biodiesel above factory maximum?
Do proper maintenance with factory spec oils, filters, etc. and have the documentation to prove it?
The codes are indicating a plugged DPF, plugged beyond a certain level, it may be time to replace the DPF.
On commercial trucks, the DPF can sometimes be cleaned "off truck".
* This post was edited 05/14/12 03:52pm by NewsW *
mowermech
Billings, MT
Posted: 05/14/12 03:35pm Link  |  Print  |  Notify Moderator
Remember, REAL troubleshooting skills these days seem to be quite rare.
If the computer can't "see" it, there must not be a problem, is the attitude seemingly common in some shops. OK, MANY shops!
With the cost of trucks these days, I would fix it and run it till it falls apart, or if I got disgusted enough with it, I would trade it for an '01-'06 Dodge CTD.
But, that's just me.
Good luck.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
NewsW
US
Posted: 05/14/12 03:36pm Link  |  Print  |  Notify Moderator
You probably have to fix it (under warranty) to trade it --- assume it was not modded.
If I were in your shoes, I would run it to 7 months from warranty expiry (powertrain), and give the Ford 6.7 / GM Duramax fuel pump issue to settle out.
Then trade.
Don't like owning orphans like the 6.4
Not enough units in field, and no more development money is going into that thing.
ib516
Up here!
Posted: 05/14/12 03:37pm Link  |  Print  |  Notify Moderator
While it is still under warranty, I'd keep it. You might reconsider that when the warranty runs out though.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
Bionic Man
Colorado
Posted: 05/14/12 03:49pm Link  |  Print  |  Notify Moderator
Anything can leave you stranded once. Repeat offenders are more worrisome. Not any fun to be stranded due to mechanical problems, especially with something in tow.
I would probably keep it until warranty runs out and see if the problem happens again. If it does, it'd be on the auction block.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
larry barnhart
wenatchee. wa usa
Posted: 05/14/12 04:49pm Link  |  Print  |  Notify Moderator
The problem is not one of the guys on this post know they will not need a tow tomorrow or next week. hard to know what can happen.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
