agility girl
Buffalo, NY (Holland)
I am looking for a power inverter that I can plug in the ciggerrte lighter of my class C that will run my TV. I hate running the genny just for the TV. Any suggestens?
Thanks, Janis
Agility girl
2010 Jayco Melbourne 29D
Millie, BC
Spyder, BC
tessa25
Colorado
Here's a startng point:
Xantrex
Palomino Gazelle G150
pianotuna
Regina, SK, Canada
Hi,
Either the Samlex, or Morningstar 300 watt units will do a good job.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Helimech
Chino Valley
I have the Xantrex 600, back up power. works great. 5 years old now
hugemoth
Bend
If you have an old CRT type TV, keep in mind that there will likely be a surge at start up to energize the degaussing coil. There won't be a surge on an LCD TV. IMO there is little difference in inverter brands nowadays. Find one that has enough output to power your TV and look for one that doesn't run the fan all the time if the noise will bother you.
Q
Mark and Linda
Smyrna, Tennessee
After reading the posts, question on an inverter, could you use one to run your refrigerator instead of using propane? Brain thinking......
Wherever I happen to park
Depending on the lighter socket it is rated for 100-200 watts tops. and likely not even that much.. Just so you know.
I recommend pure or true sine wave inverters, They start at around 300 watts so they are not good for plugging in to the lighter socket. TVs Radio, Audio gear and some other stuff (a long list) may work fine on an MSW inverter, or may not (Kind of like a casino where you pay your money and take your chances).
TSW inverters: They work, as designed, no problems.
I currently have something like five inverters in this RV. one is actually hooked up and working (There is a 75 watt MSW plug in in my computer bag, and 2 or 3 MSW's of various sizes in basement storage) these are used when I am not in the RV. (They date back to the stick house)
pianotuna
Regina, SK, Canada
Hi,
The absorption fridges draw a little over 300 watts and have a duty cycle of 2:3. That works out to about 4.8 kwh per day (or about 320 amp-hours). One would be better off with a residential fridge.
Mark and Linda wrote: After reading the posts, question on an inverter, could you use one to run your refrigerator instead of using propane? Brain thinking......
2oldman
Wilson Creek WA
Ahh.. good hijack.
big whitey
raleigh,nc
2oldman wrote: Ahh.. good hijack.
X2
