RV.Net Open Roads Forum: Tech Issues: Tineed versus Copper only Lugs?
 > Tineed versus Copper only Lugs?
cruz-in
Southern Maryland
Posted: 05/15/12 06:09am Link  |  Print  |  Notify Moderator
Hi Team,
So do you all think the tinned terminals are worth the extra $s for RV applications?
tvman44
Southwest Louisiana
Posted: 05/15/12 06:36am Link  |  Print  |  Notify Moderator
What are you doing
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
pianotuna
Regina, SK, Canada
Posted: 05/15/12 07:29am Link  |  Print  |  Notify Moderator
Hi,
I'd go for the very best I could find.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
cruz-in
Southern Maryland
Posted: 05/15/12 08:05am Link  |  Print  |  Notify Moderator
tvman44 wrote:
What are you doing
Wiring solar/batteries/inverter....
wolfe10
Posted: 05/15/12 08:09am Link  |  Print  |  Notify Moderator
Particularly for outdoor applications, use pre-tinned wire (like Ancor) and tinned connectors.
On the boat, I fill crimp connectors with silicone di-electric grease before inserting and crimping the wire.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
garym114
Bluff Dale, Texas
Posted: 05/15/12 08:50am Link  |  Print  |  Notify Moderator
Less corrosion and oxidation on tinned battery lug rings.
I made my own battery cables with tinned crimped lug rings when I installed four more batteries and an inverter/charger.
smkettner
Posted: 05/15/12 09:27am Link  |  Print  |  Notify Moderator
Tinned
675 watts solar
ktmrfs
Portland, Oregon
Posted: 05/15/12 09:41am Link  |  Print  |  Notify Moderator
Bob Landry wrote:
I've used both in marine wiring and have seen no difference other than price. While marine(tinned) wire is prefered for most applications because it resists corrosion wicking up under the insulation, there isn't much benefit to using tinned lugs. If you were soldering , then it might be helpful, but on large guage wire like battery cables, you would melt the insulation on the cable long before it got hot enough to get the solder to flow. You are better off using a good crimp tool and then using adhesive lined heat shrink to keep moisture out.
x2. exactly what I do. A proper crimp will give a gas tight seal, and the adhesive heat shrink keeps moisture out and provides a strain relief at the joint.
2011 Keystone Outback 295RE
2004.5 Silverado 4x4 CC/SB Duramax/Allison
RoyB
King George, VA
Posted: 05/15/12 09:34am Link  |  Print  |  Notify Moderator
X2 on ANCOR brand battery cable. I order 25-foot spool of Ancor marine cable along with ANCOR brand ring terminals for all my wiring projects..
I use tinned wires... Copper wiring and ring terminals is very prone to corrosion.
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
Bob Landry
Austin, texas
Posted: 05/15/12 09:35am Link  |  Print  |  Notify Moderator
2011 Tundra 5.7L
2011 Keystone Outback 277RL
