mlts22
Austin, Texas
Normally, I don't let water in the FW tank sit so long, but after three weeks, would it be still potable, should I dump it, or should I do a complete sanitizing run (fill with bleach, dump, fill with baking soda, dump)?
Oasisbob
Portland Oregon 97266
Only my opinion here but I would not consider dumping unless it sat a few month's depending on temperature etc,.
Oasis Bob
Wonderful wife & 4 Really Fun kids
2008 KIA Sedona 3.8L 24 valve V-6
2001 Bantam Trail Lite B-19
HAPPY TRAILS
RonAllen
SouthFlorida moving to Pensacola,FL
Oasisbob wrote: Only my opinion here but I would not consider dumping unless it sat a few month's depending on temperature etc,.
Ditto
Retired USN SMC
2003 Dolphin LX 36' 8.1
Eycom
32043
City water usually has enough chlorine to remain pretty safe for a month. Well water, not so. Either way, I'd drain and fill with fresh. I'd sanitize if using well water. That's been my general rule with extended travel and full timing and so far, so good. I drink from the FW tap.
RVn Full-time
Fresno Tundra Driver
Fresno,Ca. USA
No expiration on water. As long as it tastes okay it should be fine.
E.Lee Galik
garym114
Bluff Dale, Texas
It has not been hot in Austin lately. If it was August that's a different story.
Mostly temperature dependent and the source of the water.
Here'n'There
I guess if it was convenient to dump and refill I guess I would. Second thought - NO I wouldn't. Sometimes I think we make too much of this "sanitizing" - especially of city water - deal. I sanitize my potable water tank once a year but even question that necessity.
PLEASE prove me wrong someone. Has anyone seen a documented case of serious health issues related to the ingestion of water that has been sitting in a well maintained RV's sealed tank for 1 month, 2? 3? 6?.......
If the example is credible I will start sanitizing once a month! Maybe put a "skull and cross bones" symbol on the faucets when pumping water from the tank.
Here'n'There
2009 Carri-Lite 36SBQ 5th Wheel
2008 Dodge Ram 3500 Quad Cab Long Bed Diesel Dually
On the road with Here'n'There
Role of the C133 in Viet Nam
Robin1953
Ashton, WV
Here'n'There wrote: I guess if it was convenient to dump and refill I guess I would. Second thought - NO I wouldn't. Sometimes I think we make too much of this "sanitizing" - especially of city water - deal. I sanitize my potable water tank once a year but even question that necessity.
I used to sanitize at the start of every season but quit that years ago. Now that I am full timing I just keep water in the tank full time and try to consume what is in the tank every couple of months and just replenish with what is available at the time. I have added a couple of capfuls of bleach when the water was well water but that has not been very often. I have full hookups at the seasonal site but I still keep water in the tank for those times when the water goes out which it did couple of years ago for a couple of days. I generally just turn on the pump when I come back to the RV and use some of the tank water and then turn on the outside source later on when I think about it. I always turn off the water when I leave for an extended period.
Robin Brumfield
2011 Dodge 3500 DRW CC
2012 Jayco Eagle SuperLite 31.5RLTS
Sandia Man
Rio Rancho, NM
Well water I would dump but clorinated city water is OK for a couple of months.
BCSnob
Middletown, MD
Here'n'There wrote: PLEASE prove me wrong someone. Has anyone seen a documented case of serious health issues related to the ingestion of water that has been sitting in a well maintained RV's sealed tank for 1 month, 2? 3? 6?....... I have not seen any studies designed to directly test what you're asking. However, you have 2 incorrect assumptions.
1. the fresh water tank is NOT sealed (no vacuum is created when you draw from the tank)
2. the tank was NOT filled under aseptic conditions (microbes may have been added during filling)
BTW city water is not sterile; it does contain microbes (per the EPA).
another study: KINETICS OF CHLORINE DEPLETION AND MICRO........IAL GROWTH IN HOUSEHOLD PLUMBING SYSTEMS
edited 05/15/12 10:00am by BCSnob *
