RV.Net Open Roads Forum: Tech Issues: Wave 6 installation
 > Wave 6 installation
bka0721
Republic of Colorado
Posted: 05/15/12 12:19pm Link  |  Print  |  Notify Moderator
In the theme of not waiting until the season you need something, I am already working towards the cooler weather of late summer and fall. I had ordered a Wave 3 RV Heater and ended up receiving a Wave 6. In looking through the history, I have found some installation information with all of the possible ways to mount the Wave Heaters.
My question is; has anyone recessed their Wave Heater?
I have found that Wave 6 & 8 Heaters are permitted for a recessed installation and there are some issues behind a wall in my camper, which I need to access, so having the heater installed there would allow access to this area.
Thanks for any help!
bryan
08 F550-4X4-CrewChas-6.4LDiesel-206"WB GVWR17,950lbs
09 Lance 1191
600w Solar~8-6vGC2 928AmpH~Tri-Star45/4 MPPT
Xantrex 2000W
300w Solar~2-6vAGM 240AmpH~Tri-Star45/4 MPPT
Xantrex 1500W
08 BMW R1200GS Adventure
09 7X14 Enclosed Haulmark Trailer
Alpenliter
Fulltimer: Wherever we are!
Posted: 05/15/12 01:33pm Link  |  Print  |  Notify Moderator
Yes Bryan, I installed my unit into a cutout, below my entertainment center. I used the optional chrome mount bezel fora more finished look. After using it several days, I noticed the wood above the heater was dark and discolored. Too much heat was migrating up from the heater. I solved this problem by mounting two screws into the chrome bezel, leaving them out about one inch. Then I used a small insulated cookie sheet that had a raised lip on one end. I wedged that into the screws and it's now acted as a heat deflector that actually pushes the heat out from the face of the heater.
My first Wife Linda, 45+years
2004 F-450 CC, DRW 6.0 Classy Chassis Upgrade
Bulletproof Diesel upgrades
1997 33' Alpenlite
400 Watts Solar
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Vietnam Vet '67-'68
Extreme Makeover RV Style!
big whitey
raleigh,nc
Posted: 05/15/12 05:55pm Link  |  Print  |  Notify Moderator
bk i installed my wave 3 in a recessed area in my TC and as others posted it began to scorch the cabinet above the recess.i too built a heat reflector which both solved the issue and provided a good reflective object for the heat to bounce off which is a very good thing for radiant heat.
bka0721
Posted: 05/16/12 03:14pm Link  |  Print  |  Notify Moderator
Big_whitey, Alpenliter, Thanks for responding! Your information was something I had not considered, burning of the cabinets above the heater. Heating my home with a Buckstove Wood Burning Stove for over 10 years, I should have figured that, but your suggestions were helpful.
One of the things I did see in the literature from the Wave Heater manufacturers was not to recess mount the Wave 3. The only heaters that the factory recommends, is the Wave 6 & 8. I wonder if this will be a help in reducing the heat, upwards.
I did see that there is a fascia available for recessed mounting, but it is in Chrome. With everything in my Truck Camper; Flat Black, it would be nice to see it in a Flat Black. Obviously I won’t be able to paint chrome, but maybe I would be able to powder coat it.
Thanks for your help and not a response in not to do it. Sometimes not hearing information can be information in itself.
bryan
big whitey
raleigh,nc
Posted: 05/16/12 06:50pm Link  |  Print  |  Notify Moderator
wonder why they specifically don't recommend the wave 3 for this application(recessed)but make no mention of the other 2 models?
bka0721
Posted: 05/17/12 07:27pm Link  |  Print  |  Notify Moderator
That is what puzzled me too. Obviously, to me at least, the Wave 6 & Wave 8 would radiate more heat and I would have concerns with this application if they didn't prescribe it was acceptable to recess teh Wave 6 & Wave 8.
b
