bkirkpatrick
Brea / Orange County, CA
Doing a dry run with the BP 170watt solar panel and my controller says 3.5 amps / 45 watts. It is 12:51 PM in Los Angeles and about 80 degrees with full sun. Any suggestions
Raptor - Modifications
2oldman
Winchester WA
How charged are your batteries?
smkettner
What is the battery voltage?
MPPT controller?
675 watts solar
bigfootford
Fair Oaks, California
If your battery (s) are charged, or almost then you will see only what they will accept..
Turn on a fan and see if the amps go up...Keep turning on 12vdc stuff until the amps stop climbing.
Do you have a battery monitor like the Trimtric or Link-10.
Jim
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Mich 245/70XDS2's, Bilstein shocks, air bags/pump, EU2000, PD 9260,Lifeline 100ah, 200W. solar, Morningstar Sunsaver 15A/ display panel, Trimetric, Delorme/laptop, Holux gps rec,led lights, Wave-3 heat.
bkirkpatrick
Battery Voltage was at 12.5/12.4 prior to hooking it up (now at 13.9) and the MPPT controller is a Samlex solar 30a controller
2oldman
Winchester WA
Given those numbers, run something 'heavy' using your inverter like the MW for a couple minutes.. then see what you're getting from the panel.
bkirkpatrick
bigfootford wrote: If your battery (s) are charged, or almost then you will see only what they will accept..
Jim
Turned on all the 12v lights / fan and all it did was change the battery volts (dropped to 13.4)
3 tons
CA.
The 12v lights may not be a substantial enough load...Do you have an inverter??
bkirkpatrick
Yes. Just ran the hair dryer off the inverter for about 15 seconds and the amps climbed by .5 and the watts increased by 5 watts. I thought there would at least be a setting telling me what is actually coming in from the panels (true watts & amps).
smkettner
Is it this one?
http://www.samlexamerica.com/products/ProductDetail.aspx?pid=60
Manual p28: The scc-30ab is a Series Type of PWM (Pulse Width Modulation) Charge Controller.
Is this the panel?
BP 3170
That 24v panel has Isc spec at 5.2 amps so 3.5 is a little low but I think you are mismatched on panel vs controller.
