RV.Net Open Roads Forum: Initial Solar Hookup only shows partial watts and amps
 > Initial Solar Hookup only shows partial watts and amps
Page of 13
bkirkpatrick
Brea / Orange County, CA
Posted: 05/15/12 08:27pm Link  |  Print  |  Notify Moderator
What about the Xantrex c40? Or is it a PWM which means that my PV must be the same as my battery bank?
Raptor - Modifications
mena661
Posted: 05/15/12 08:29pm Link  |  Print  |  Notify Moderator
bkirkpatrick wrote:
I love the knowledge here. What I need is an MPPT controller with a remote meter/monitor.
Here are a few but the one that smk recommended (MorningStar SunSaver SS-MPPT-15L) is probably the least expensive that isn't junk.
http://www.solarblvd.com/Charge-Controll........MPPT-Charge-Controllers/c6_46/index.html
Trojan L16 6V's 740 Amp-hours
smkettner
Posted: 05/15/12 10:17pm Link  |  Print  |  Notify Moderator
Samlex is 50 Voc max
Rogue is 60 Voc max
See links above to manufacturer's website
675 watts solar
pianotuna
Regina, SK, Canada
Posted: 05/15/12 10:10pm Link  |  Print  |  Notify Moderator
Hi,
I thought the Rogue would accept up to 60 volts VOC?
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
2oldman
Wilson Creek WA
Posted: 05/15/12 09:36pm Link  |  Print  |  Notify Moderator
Was just reviewing all the discussion on this from back in January. Seems like controllers were talked about.
full_mosey
Oklahoma
Posted: 05/15/12 09:54pm Link  |  Print  |  Notify Moderator
bkirkpatrick wrote:
Doing a dry run with the BP 170watt solar panel and my controller says 3.5 amps / 45 watts. It is 12:51 PM in Los Angeles and about 80 degrees with full sun. Any suggestions
Your panels are 36V nominal. That is an odd Voltage. It could be difficult to find an inexpensive MPPT controller.
The Rogue 3024 is capped at 24V so it won't work with your panels.
You could use the MS MPPT 15, but it can only handle one of the 170W panels as it has a 200W upper limit for a 12V system.
Your panels are 44.2Voc. I am amazed you have not let the magic smoke out of your Samlex!
HTH;
John
full_mosey
Oklahoma
Posted: 05/15/12 10:21pm Link  |  Print  |  Notify Moderator
This is what confuses me re the Rogue:
Use with 12-volt or 24-volt nominal PV arrays (60-volt Voc maximum)
The OP has 36V nominal panels.
HTH;
John
2oldman
Wilson Creek WA
Posted: 05/15/12 10:28pm Link  |  Print  |  Notify Moderator
I read the spec as 24V nominal. 36v is Vmax.
The Rogue is capped at 60voc.
He has not let magic smoke out because VOC is for "open circuit".
mena661
Posted: 05/15/12 10:45pm Link  |  Print  |  Notify Moderator
According to that link for these panels, Vmp is 35.5V, Voc is 44.2V, Imp is 4.8A, and Isc 5.2A.
MrWizard
Traveling
Posted: 05/15/12 10:47pm Link  |  Print  |  Notify Moderator
well everybody has pretty much Nailed it,
you need an MPPT controller
you can parallel or series the two panels depending on which controller you decide on,
but the samlex is not going to convert the excess volts to give you all the watts
any PWM non-mppt controller is going to work the same as the samlex, 'CHOP' off the voltage keeping the amps at what ever the panels are putting out, which means wattage lost
with panels with that voltage, MPPT is the only way to actually utilize them and get the most output power into the batteries
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
Page of 13
