RV.Net Open Roads Forum: Initial Solar Hookup only shows partial watts and amps
 > Initial Solar Hookup only shows partial watts and amps
Page of 13
Hurricaner
Hurricane Utah
Posted: 05/15/12 02:22pm Link  |  Print  |  Notify Moderator
Something is wrong. You should be putting out at least 8 amps and you would have seen that as soon as you turned on all the lights, even if the battery was fully charged. Edit, is this a 24 volt panel!!! Are you reading panel amps or battery amps?
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
bkirkpatrick
Brea / Orange County, CA
Posted: 05/15/12 02:48pm Link  |  Print  |  Notify Moderator
smkettner wrote:
Is it this one?
http://www.samlexamerica.com/products/ProductDetail.aspx?pid=60
Manual p28: The scc-30ab is a Series Type of PWM (Pulse Width Modulation) Charge Controller.
Is this the panel?
BP 3170
That 24v panel has Isc spec at 5.2 amps so 3.5 is a little low but I think you are mismatched on panel vs controller.
The panel is an BP sx170 and that is the correct controller.
Just got off the phone with tech support at samlexsolar and they confirmed what you said. The charge controller that I have is just that. It is meant for a 24v battery bank. It does have a battery bank switch setting for either 12 or 24v but running at 12v cuts everything by pretty much a third. Their recommendation was one of two: Go out and buy an MPPT controller or take my 4 six volt batteries and run them in series. However, since I have the Freedom 458 (2000w/100a) inverter, they did not recommend that since I would be pulling current from withing the battery bank. Any suggestions?
Raptor - Modifications
wild bill
Mira Loma, Ca. USA
Posted: 05/15/12 03:12pm Link  |  Print  |  Notify Moderator
Take a look at this http://www.altestore.com/store/Charge-Controllers/Solar-Charge-Controllers/PWM-Type-Solar-Charge-Controllers/Morningstar-Charge-Controllers-PWM/Morningstar-TriStar-TS-45-Charge-Controller-without-Display/p806/ as it will do what you want for not a lot of money......It is not MPTT ....I have had mine installed for over three years and it has been problem free....
05 Dodge 3500 Q-Cab,GearVendor 8 Sp,PacBrake,Banks intercooler & intake,TST R49,Transferflow 70 tank,TrailerSaver Hitch,05 Raptor 3612,Second AC, solar 6 battery sys Xantrex 3000, WEB SITE
http://home.earthlink.net/~wbrown02/wildbillwashere22/index.html
smkettner
Posted: 05/15/12 03:32pm Link  |  Print  |  Notify Moderator
Well you need to sell or return something and I assume that would be the controller. I assume you want an MPPT as that is what you thought you were buying.
MPPT is expensive so to be cost effective you want to size it to what your final configuration will be. Are you going to stick with a single 170w panel?
Closest I know to recommend is MorningStar SunSaver SS-MPPT-15L Charge Controller
This is good for 200w max on a 12v battery
http://www.morningstarcorp.com/en/sunsavermppt
* This post was edited 05/15/12 04:08pm by smkettner *
675 watts solar
mena661
Posted: 05/15/12 03:43pm Link  |  Print  |  Notify Moderator
X2
Trojan L16 6V's 740 Amp-hours
bkirkpatrick
Posted: 05/15/12 04:32pm Link  |  Print  |  Notify Moderator
I have two of the 170 panels.
bkirkpatrick
Posted: 05/15/12 04:39pm Link  |  Print  |  Notify Moderator
When a controller says, "PV Open Circuit Voltage: 30 VDC Maximum" is it talking about the panel voltage?
smkettner
Posted: 05/15/12 04:44pm Link  |  Print  |  Notify Moderator
Yes that is Voc spec at normal temperature. Voc will rise slightly as temp drops.
30VDC max controller would probably be for a 12v panel.
* This post was edited 05/15/12 04:52pm by smkettner *
smkettner
Posted: 05/15/12 04:50pm Link  |  Print  |  Notify Moderator
Rogue controller might be a good fit. Lots of good posts about these.
The panels will need to be in parallel, series Voc is too high.
http://www.roguepowertech.com/products/mpt3024.htm
You can get snap on MC parallel connectors and avoid the combiner box.
If you want to run panels in series it will cost a bit more to go Morningstar Tristar MPPT 45.
* This post was edited 05/15/12 05:10pm by smkettner *
pianotuna
Regina, SK, Canada
Posted: 05/15/12 04:54pm Link  |  Print  |  Notify Moderator
Hi,
Unfortunately the fix is an MPPT controller. You could try an el-cheapo from Ebay. Or you could take SMK's advice.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Page of 13
