RV.Net Open Roads Forum: Tow Vehicles: Truck Sputtering Update
Search only in Tow Vehicles
 > Truck Sputtering Update
ceaser 22000
Michigan
Posted: 05/15/12 02:08pm Link  |  Print  |  Notify Moderator
Replaced Battery and got some lucas oil fuel injector cleaner truck is running alot better today then yesterday don't know if this was the case but I will follow up with fuel filter and fuel injectors if it starts again thanks for all the input. Oh possibility that I did get some winter fuel because this all started after a fill up the prior day that also maybe case.
Brian
midnightsadie
ohio
Posted: 05/15/12 02:43pm Link  |  Print  |  Notify Moderator
try a can of SEA FOAM it does wonders. cleans things up and dries out some water.
ScottG
Bothell Wa.
Posted: 05/15/12 03:47pm Link  |  Print  |  Notify Moderator
X2 on the Seafoam. It's the only inj. cleaner that does anything in my experience.
Scott, Grace and Wesly
H0NDA eu2000i
NewsW
US
Posted: 05/15/12 04:13pm Link  |  Print  |  Notify Moderator
Brian
Tell us about the gas station you went to....
Low volume... out of the way?
Off brand?
Sounds like too much butane was added to the mix, making for too much vapor.
Let me guess.. the day after you filled up was quite warm.. unusually so for your area?
That does it.. fuel
