crimmps49
Wisconsin
We posted about our 2852 Dometic refrig in our new-to-us MH. Someone suggested there were many recalls on these, so I reasearched and found our serial number is one of them recalled for service work. We don't know if this was ever taken care of, but it seems it could be why ours isn't working. Would this recall still be honored since it is quite old?
MudChucker
Niverville Manitoba
Doesn't hurt to call and ask...
2005 PILGRIM 274RL 5SS
2007 GMC Sierra 2500HD SLT 6.0
garym114
Bluff Dale, Texas
It is probably not why yours is not working. The recall will not fix a refer that is not working.
CavemanCharlie
Storden,MN
Not enough info. What is wrong with it and what was the recall about? I was able to fix a problem on my 1993 fridge. So, we may be able to find a solution but, we don't even know what the problem is yet.
JJBIRISH
Butler, PA, USA
Chances are the recall would need to be preformed if it hasn’t already been done… that doesn’t mean they would have to repair what isn’t working free of charge…
The recall may have been done sensed the problem and placed the fridge in lock out…
Love my mass produced, entry level, built by Lazy American Workers, Hornet
IAMICHABOD
Sunny So Cal
An easy to find out if your recall has been done is this it showes how it is done. I took it and looked at mine and it looked like the pictures on the instructions.If it does not then you know that it hasn't been done.If it is on the recall list and hasn't been done the website you looked at will tell you where,in your state and area, where it can be done.just take it there and they will do it.No matter the age if the frige that you have is on the recall list.As far as the cooling problem,that is a different thing.
2006 TIOGA 26Q CHEVY 6.0 VORTEC
Recycled El Monte RV Rental
Buying A Rental Class C
crimmps49
Wisconsin
Thanks all. I called Dometic and our recall was never done. She said that is probably why the gas option doesn't work. Hope so, since the recall repair is free!
aftermath
Washington State
I have had this recall done to two trailers. There was an ever so slight chance that a fire could break out in the flue area so, instead of fixing the probability of a fire they engineered a baffle that would contain the fire and not allow it to spread to the surrounding area. This is what was explained by both of the techs who worked on my trailers.
I can't imagine that not having this baffle installed would cause your fridge to stop working on propane. I would be interested in hearing back when you take it in for the recall. It might be something as simple as a blocked flue or an obstruction in the gas line like a spider web or something. Please let us know how this is resolved.
2008 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
Prodigy Controler
crimmps49
Wisconsin
Will do aftermath. She was not a technician--either way we need the gas part functioning eventually. Not many places here in WI that are listed on Dometic website for repair, so trying to schedule in NC when we are by our daughter.
