RV.Net Open Roads Forum: Best truck to haul a triple slide Eagle Cap 1165?
 > Best truck to haul a triple slide Eagle Cap 1165?
Boatycall
Tacoma, WA
Posted: 05/15/12 06:58pm Link  |  Print  |  Notify Moderator
I'm thinking... only thinking about it. Saw an Eagle Cap 1165 triple slide, a lot like the Host Everest. My poor, little, under weight F350 Dually would probably not like it.
Those who have "big" campers, what's best truck to haul one with, and it has to have 4x4 and Crew Cab. 4x4 is mandatory, I still like camping in semi-rural or snowed in places, hence the reason I will never get a motorhome.
01 F350 DRW 4x4,Torklifts,SuperHitch,F550 Rear Suspension,Roadmaster ANTI-Sway Bar,Rancho 9000s
2012 AF 1150-4 Trojans,1.5kw Inverter,32" LCD,19" LCD,Basboard heat,Dish Tailgator,Ice maker,3 awnings,80a charge circuit,Polk Audio/Kenwood/Kicker sound system
JoeChiOhki
Sauvie Island, OR
Posted: 05/15/12 07:06pm Link  |  Print  |  Notify Moderator
4x4 F550 comes to mind .
CB Channel 17 Redneck Express
fordsooperdooty
Posted: 05/15/12 07:12pm Link  |  Print  |  Notify Moderator
It weighs 4525 Lbs dry and Eagle Cap owners say likely pushing 6000 wet and loaded. F-450 Dually or a 4500 Series Chevy Dodge Dually should do it.
Next series up would be even better!
Generally these trucks have a wider track that the F350/3500 series for an even better stability.
KD4UPL
Swoope, VA
Posted: 05/15/12 07:20pm Link  |  Print  |  Notify Moderator
I would recommend a 4500 or 5500 Dodge with an aluminum flatbed. You can add some tool boxes above and below the bed for storage. This is the kind of rig I want to build when my current Chevy dually needs replacing.
SkipJ
Michigan
Posted: 05/15/12 08:03pm Link  |  Print  |  Notify Moderator
Get something big enough before they are banned.
1992 Airstream B-190 van
1989 Airstream 25' Excella Trailer
Outfitter Apex 9.5 Truck Camper Ford F-350 Diesel 4x4
Butch50
Bentonville, AR
Posted: 05/15/12 09:00pm Link  |  Print  |  Notify Moderator
When I had me AF1140 I used a 2006 Ford F550 with a pickup bed installed on it. Kind of like Mooney has his camper on. I had all kinds of extra capacity left over. If I was ever to go to a big camper again it would be the same setup or a Dodge 5500 with similar setup.
Butch
2011 F350 KR 4X4 CC LB SRW
2012 Northern Lite 10 2 CDSE
2008 Custom Weld 17' Boat
2010 Can-Am 650XT Outlander Max
2012 Harley Tri Glide
jimh425
Western WA
Posted: 05/15/12 09:54pm Link  |  Print  |  Notify Moderator
I think a 550 would handle it as well, or one of the giant Chevy's. A 350 DRW with 19.5s probably could work.
'06 F350 Lariat Supercab SRW, 6.0 PSD 4x4 Long Bed, Intake Elbow, Walker Big Truck Muffler. '06 Host Rainer 950 Double Slide, Fastguns. Firestone Air Bags, Rancho 9000s, Vision 19.5s with Hankook DH-01 245s, Energy Suspension bump stops.
Francesca Knowles
Port Hadlock, Washington
Posted: 05/15/12 11:03pm Link  |  Print  |  Notify Moderator
Boatycall wrote:
"2012 Arctic Fox 1150 Four 6v golf carts, 1.5kw inverter, 2.5kw gen
'09 Cyclone 4012 Toyhauler, four 6v Golf Cart batts, 5.5kw gen, 1.5kw true sinewave inverter, ice maker
'01 F350 Dually 4x4 Crew Cab,Torklifts,Super Hitch,Jasper Transmission's MonsterBox"
Your wife wants me to tell you that you have way too many toys already...
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
skipdoc
larsen,wis,usa
Posted: 05/16/12 06:04am Link  |  Print  |  Notify Moderator
I have a Host Everest and haul it with 08 F-450 4X4 crewcab.It handles it great.I think having this size truck or bigger would be your best bet.You may also consider if you are going to tow a boat or trailer with atv's or other toys.We tow both and don't even know they are there.Good luck!
Skipdoc
2009 Host Everest
2008 F-450 4x4 crew
~DJ~
Boise, Idaho
Posted: 05/16/12 09:29am Link  |  Print  |  Notify Moderator
F550 min. F450 has little more payload than an F350. Built more for towing.
Check out BKA0721's rig!!!
2011 F250 Super Cab Lariat 6.2 373 FX4 Short Box 4" BDS, 35" Toyos, TorkLift, 16.5K Warn, Locked & Loaded
2007 SunLite Pop Up
