super_camper
Ontario, Canada
So I could faintly tell there was an odd smell when washing my motorhome. Sure enough I got a flashlight and looks to be a nest of some kind on the engine, at the back of the compartment. So I cleaned that up and it was horrible - like really bad.
Anyway, I pulled the doghouse cover and found the critter has cut a wire or a hose - not sure what it is so I snapped a picture. The MH ran with this cut so I'm hoping I can get to the garage with it.
Any ideas what this is for???
super_camper
Ontario, Canada
BTW: the pic was snapped from inside the MH, the red hose is in the upper right corner when facing toward the front window.
lj2654
weeki wachee, florida
looks like a vacuum line of some kind....
2001 Beaver Contessa Naples 40
2005 Honda CRV Toad
retired AirForce
Dakzuki
Carnation, Wa, USA
lj2654 wrote: looks like a vacuum line of some kind....
Agreed. There are a few things that run off vacuum (like heater diverter doors) so you may not notice until you need it. Should be an easy fix.
2011 Itasca Navion 24J
95 Chinook Premier
Francesca Knowles
Port Hadlock, Washington
Squirrels...
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
crasster
Dallas
LOL, def a vac line. Autozone should be able to find you a part for it, or match the tube.
Critters...
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
ron.dittmer
Northern Illinois
I agree that it looks like a vacuum hose. Snip off a 1/4" of a chewed up end to make a clean end, take that snip to an auto parts store and ask for help there to size up a 6" vaccuum tube extension, go back home and slip the extension over both ends of the tube. It will cost you $2 instead of $60, and you will have learned something.
2007 Phoenix Cruiser model 2350, with 2006 Jeep Liberty in-tow
rvten
Crossville,TN
If you can find both ends. Just splice them together. You can get the plastic barbed connectors at any auto parts store.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is no B+
j-d
Sunny Florida USA
What Ron said. Just get a piece of vacuum hose with an inside diameter that's a snug fit over the cut tubing. Put it on and BAM!: permanent repair.
God Bless, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100
joeprinter
Fayetteville, NC
Yep vacuum line, could have been much worse, a man I know DP had mice eat his electrical in the bays, 10K repair.
"2012 Forest River 360 DS"
"Ford V-10"
"2013 Toyota Corolla on Tow Dolly"
