NorthernLimits
Michigan
In photobucket I have a album called "5th wheel".
When I copy the photobucket link, it has the percent 20 part in the link to indicate the space character in the words "5th wheel".
Every time I try to post a pic from that album, or any other one that has a space, this forum won't post it. Just says "connection was reset".
If I copy and paste the link, and then remove the percent 20 and just put a space there, then it works.
I post on a lot of forums and this is the only forum that has the problem.
Posting from rv.net
Example:
I put the in bold so you see where it's at.
Edit: I just tried to post test of the link, not a pic, not a link, and it did the same thing.
NorthernLimits
Michigan
Ok, more info.
The error happens even if I just type the percent sign and 20.
Francesca Knowles
Port Hadlock, Washington
Photobucket has one of those webcrawlers that "finds" its images and deletes them...you may be encountering problems with that.
Recommend trying another photo server- at least until this website converts to a system that allows us to upload pics from our own computers like more "modern" websites do.
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
NorthernLimits
Michigan
Odd....can't even type just the percent sign.
SCVJeff
Santa Clarita, CA.
Works for me
Jeff - WA6EQU
pulsar
Lewisville, NC
The RV.Net portal has been having issues for more than a week. One of the symptoms is the inability to process the % symbol..
The Woodall's portal doesn't have issues, at least, for me.
Another work-around, if you have to use the RV.Net portal, is to change the 'http' in the address line to 'https', refresh the page and then make the post. That is what I did to post the % symbol in this post. (I'm using the RV.Net portal,) Apparently, the SSL server is not having issues.
Tom
NorthernLimits
Michigan
SCVJeff wrote:
Works for me
Did you read my post? Your pic does not have any spaces in the album name or in the picture so it doesn't have a percent 20 in it.
NorthernLimits
Michigan
pulsar wrote: The RV.Net portal has been having issues for more than a week. One of the symptoms is the inability to process the symbol..
Another work-around, if you have to use the RV.Net portal, is to change the 'http' in the address line to 'https', refresh the page and then make the post. That is what I did to post the symbol in this post. (I'm using the RV.Net portal,) Apparently, the SSL server is not having issues.
Tom
thanks Tom. Wasn't sure if you guys knew about it.
fla-gypsy
North Florida
%%%%%%%%%. Working for me, I have never had a problem posting photobucket pics to this site
SCVJeff
Santa Clarita, CA.
NorthernLimits wrote: SCVJeff wrote:
Works for me
Did you read my post? Your pic does not have any spaces in the album name or in the picture so it doesn't have a percent 20 in it. Yep, grabbed the wrong pic. It was late. It no workie..
Jeff - WA6EQU
